SHL, SHR, ROL, ROR, SAR instructions
For some reason these instructions seem a bit strange. Like, I imagined them sort of like a shift register. And the 'wc' result would be effected by the last shift. Spent a few hours before realizing why no other bit (other than lsb or msb) affected the result.
What is the purpose of being able to shift more than 1 place yet 'wc' is only influenced by 'original' bit 0 (or 31 for left shift/rotates)? Seems limited.
Sure seems like it would make more sense to effect 'wc' with the last bit shifted out. So now need to do 'and register,#n' where n = the desired bit position or mask bit. (Is there a better way?) (A potential Trap??)
Harley Shanko
Harley Shanko
Wider shifts are a hardly to be expected plus in such a machine as the Propeller. Shifting more places is generally a quite different application from algorithms shifting just one place.
Best do NOT use the flags when shifting more than one place. Shifting N places is NOT N times shifting one place!!
I've often wondered about the design considerations that led to the "first-bit-out" choice. I have to assume it wasn't an arbitrary decision; and, given (perhaps wrongly) that both could be implemented with equal difficulty, I have to believe that "first-bit-out" was judged the more useful. It would be interesting to get inside Chip's mind on this one. I hope he kept a journal. Perhaps some day he will write a book akin to Tracy Kidder's The Soul of a New Machine, a highly entertaining read!
Tracy Kidd was/is a journalist with good but limited understanding of the technical aspect.. Most he was interested in the "human factor"!
But may be Chip will hire deSilva to do this job
Paul Baker
Post Edited (Paul Baker (Parallax)) : 10/5/2007 4:11:22 AM GMT
The ability to barrel shift more than makes up for the occasional instruction required to test the result. Non issue.
When you only have 512 words to play with.. (yeah yeah, I know it's 496) every cycle/instruction counts!
It's very well explained in Phil Pilgrims Tricks and Traps document (I have that page stuck to the wall next to my monitor).
Extremely useful stuff.
Rereading all the replies, I wanted to use SHL variable,#n wc,nr. Not to disturb any bit positioning, just to check if a bit was 1 or 0.
Am now using AND variable,#m where 'm' is a mask bit for the desired position. Not quite as clean, but works. Probably several others could be used. SHR wasn't optimized, IMHO.
Harley Shanko
Post Edited (Harley) : 10/5/2007 3:20:54 PM GMT
ANDing is the usual and accepted way to do what you want. For readability, you can create your mask "on the fly", viz:
····and variable, #1 << bitposition nr,wz
Incidentally, this is equivalent to
····test variable, #1 << bitposition wz
which is just an and with the nr preset.
Post Edited (Phil Pilgrim (PhiPi)) : 10/5/2007 3:35:15 PM GMT
I thought I read somewhere along in time that assembler instructions couldn't be as complex as Spin. Are you impling that one could also write
····test variable, (#1 << bitposition1 AND #1 << bitposition2) wz ' ???
Does the manual define how complex 'value 2' could be for 'test' and other instructions? I don't recall ever seeing such a limitation for assembly.
Harley Shanko
However what you have been writing is pure nonsens, as # is an operation code modifier and has nothing to do in the places where you put it. Under certain circumstances
will work.(I presume you wanted to say OR ratherthan AND ...) The circumstances are: The constant expression has to yield a value <512
You can even say
You don't want to AND your mask positions: your mask will end up being zero. Here's the correct way, using a bitwise OR:
····test variable, #(1 << bitposition1) | (1 << bitposition2) wz
Addendum: In recognition of deSilva's admonition, "bitposition" must always be less than 9. This means you can't "reach" the upper bit positions using an immediate mask but, rather, must preload the mask into a memory location and use that instead.
Post Edited (Phil Pilgrim (PhiPi)) : 10/5/2007 4:29:35 PM GMT
No, it wouldn't. That is why I was after this fact: "A #N shift is not an N times #1 shift"
The INTEL-style "rotate through carry" are beasts of very special kind. They can be best described as "rotate nine", i.e. The carry should be considered as the nineth bit, then imagine a rotate, that decouple the nineth bit again..
This clarifies things very well. I just didn't write precisely what I intended (meant first mask bit 'and' second mask bit, or the first OR'd with second).
Harley Shanko
80x86 rotate left and right through carry,with RCL,RCR mnemonics
as do 68K with ROL,ROR with optional ROXL,ROXR using extend flag X.
Not sure about 80x86 ROL ROR ( only got an old 386 H/W manual ),but
would suspect carry holds state of last shift,otherwise there's no point
having the instruction.
Certainly true for 68K,and I suspect for nearly all other processors!!
Best Regards to All
Ian
:- We are here on earth to do good for others; What the others are here
for I have no idea.
