Dataflash reset problems
Hi All,
Im having a few issues with the 16Mbit SPI dataflash im using.
I can get it to write and read now problems using both buffers, however if a prop reset occurs, or the power cycles, during a read/write routine, it corrupts all the data and I have some major issues using the DF for a bit.
I then erase the entire chip (using 512 block erase's) and attempt to write again. For some time afterwards, the writes only write 1's...well at least thats what I see when i play it back.
After leaving it for a while things just fix themselves, or at least they seem to!
Here is a snippet of code I use. When the prop first boots, DF_SCK is set to 1 and all pins are outputs.
To do anything, first I combine the opcode with the address etc and call DF_Send(data, 32), then DF_send any data required, the DF_END
Any help/experience appreciated!
Alec
-Alec
My our page
PRI DF_Send(data,bits)
dira[noparse][[/noparse]DF_DATA]~~
dira[noparse][[/noparse]DF_SCK]~~
dira[noparse][[/noparse]DF_CS]~~
outa[noparse][[/noparse]DF_CS]~
repeat 1
outa[noparse][[/noparse]DF_SCK]~
data <<= (32-bits)
repeat bits
outa[noparse][[/noparse]DF_DATA] := (data <-=1) & 1
repeat 1
outa[noparse][[/noparse]DF_SCK]~~
repeat 1
PRI DF_Recieve(bytes) : temp
if byte > 4
bytes := 4
repeat (8*bytes)
temp <<= 1
temp := temp | ina[noparse][[/noparse]DF_DATA]
repeat 1
repeat 1
Return temp
PRI DF_End
outa[noparse][[/noparse]DF_CS]~~
Alec
-Alec
My our page
Found it, was Mike Green:
"If that (a brownout) is important, use a large enough electrolytic capacitor across the regulator output to keep the Propeller functioning for a substantial part of a second and use an I/O pin to measure the unregulated input to the 3.3V regulator. Best is to use a voltage divider. If the input to the 3.3V regulator is from a 5V regulator, divide the 5V down so you get about 1.5V when the input to the 3.3V regulator is about 4.5V. Tie that to a Propeller I/O pin. It will normally be high. As the input to the 3.3V regulator drops below 5V, the I/O pin will go from high to low indicating that power loss is emminent and your backup cog can write what it has and everything else can come to an orderly halt waiting for the expected power off to occur.
You'll have to figure out how to recover when the power comes up again."
in this thread: http://forums.parallax.com/showthread.php?p=677938
Post Edited (Fred Hawkins) : 10/4/2007 7:44:59 PM GMT
Unfortunatly this is not an issue regarding brownouts as that is already solved.
This latest problem occurs when I perform a reset by pulling the reset pin low (via the prop tool and PropTerminal).
It corrupts all my data and make the DF useable Im just now trying to figure out how to make it useable again)
Re. the write times.
I am alternating between buffers so when 1 is writing I can fill the other one etc etc etc.
Each buffer takes 1.35 seconds to fill which give it plenty of time to do its thing [noparse]:)[/noparse]
Thanks for the suggestion though.
Any thoughts?
-Alec
My our page
Its not so much of a problem when the device is in operation, but while testing there are some cases where I need to re-program the device while it is performing its function (ie logging data).
The prop tool resets the device first, which is what is causing the problems. [noparse]:([/noparse]
If I reset between writes/reads there is no problem, but im logging at 128Hz so its gets tricky trying to reset within 7.8ms :P
Also, lets say the user of the device is playing back the data while they connect the usb cable to upload the data to a PC, this will force a reset and corrupt the data [noparse]:([/noparse]
There is nothing in my code which reset's the prop, its external programs which I wish to interface with that are making my hair fall out [noparse]:)[/noparse]
Alec
-Alec
My our page
-Alec
My our page
Im trying to code it so that it this occurs again I won't have any problems [noparse]:)[/noparse]
-Alec
My our page
It was suggested to me that the fact I am operation in mode 3 (read + write on separate datalines) could cause some trouble seeing as I have mine combined on 1 line!
I am testing mode 0 and will let you know how I get on.
-Alec
My our page
