Table in assembly
Hello,
I need copy values from tables in COG memory to the HUB memory.
When I start this code with "ptr from 0 to 5", State contains next values:
Where I make error please?
Thanks Lafet
VAR
Byte State
OBJ
debug : "FullDuplexSerialPlus"
PUB Main
Debug.start(31, 30, 0, 57600)
coginit(6,@entry, @State)
Debug.bin(State,6)
repeat
DAT
entry mov ptr, #2 ' for an example, get third value
call #look
:stop jmp #:stop
look mov data, ptr ' ptr is a table index (0 to n-1)
add data, #table 'pointer to Table + offset
mov :inline, data
nop 'pause for pipelining
:inline mov data,0-0 ' get byte value from table
wrbyte data, par 'save table values to HUB memory -> State
look_ret ret
table byte %100110
byte %010110
byte %010011
byte %001011
byte %001101
byte %100101
data res 1
ptr res 1
ptr State 0 001010 1 001011 2 001100 3 001101 4 001110 5 001111
Thanks Lafet
Edit: BTW, you need not intermediately store the table value; you can directly write from the table, in that case use MOVD
movd :inline, data nop 'pause for pipelining :inline wrbyte 0-0, par 'save table values to HUB memory -> StateFurther Edit: To explain your read values: As you force a NOP with your MOV, they are just the addresses of the table entries, formerly contained in DATA, as TABLE starts at cell 10 =%1010.
For some unclear reasons the COG has loaded fast enough... I should have thought Ariba were right with his second remark.....
Post Edited (deSilva) : 10/3/2007 9:35:06 PM GMT
An other problem is that you don't wait after coginit until the Assembly cog is startet and has written the State value before you do the 'Debug.bin(State,6)'. You can add a waitcnt-Delay or wait for a value <>0 in State.
You can use PASD for debugging such problems:
http://forums.parallax.com/showpost.php?p=0
Andy
