The LM34 and BS2
Hey all,
I need some help here. I'm trying to find a schematic for the lm34 in use with the bs2. At the same time needing a way to test the lm34 to see if its works. Any help is good.
Ferris!!!!
Ferris!!!!
Ferris
Dave
Dave Andreae
Parallax Tech Support·
- Rick
Ferris!!!!
result VAR Word LOW 0 DO RCTIME 0,0,result LOW 0 DEBUG ? result PAUSE 500 LOOP
If it is a standard BS2, the value printed will be something near 900 when the LM34 is at 70 Fahrenheit, and vary from around 1230 at 50 degF to 700 at 100 degF. It can be calibrated to read in temperature, but it will work better if you do get hold of a real ADC chip to add to your BS2 setup.
For protection of the Stamp, it is a good idea to put a 220 ohm resistor in between the Stamp pin and the junction of the LM34 and capacitor. It will probably need the +V terminal of the LM34 to be attached to a voltage like 7-12 volts (Vin), and won't work well on 5 volts (Vdd).
Tracy Allen
www.emesystems.com
edit: Also be careful, the pin out diagrams for TO-92 devices are often drawn as if you're looking at the bottom of the package and not the top like an IC. I fried my first LM34 this way.
- Rick
Post Edited (RDL2004) : 10/3/2007 9:53:25 PM GMT
Ferris!!!!
I have the lm34 to work. Now I need a progam for it. I could use some help.
Ferris!!!!
- Rick
Ferris!!!!
