Parallax USB Oscilliscope not working!
I just got my Parallax USB Oscilliscope the other day, and installed the software (version 4.0.0) and connected the unit. Windows assigned COM4 to the device, so when I launched the software I selected COM4 in the list. At this point the software became very sluggish in response, and continued to indicate that the 'scope was not connected. I'm running Windows 2000 SP4 with Administrator privileges. Any ideas?
Chris Savage
Parallax Tech Support
I can try that, however I know for sure that there are only two other serial devices consuming COM resources - the hardware RS-232 port on the computer (COM1) and the internal modem (COM3). I have an IR port (this is on a laptop btw) but it is disabled in BIOS and shows up on COM2 when enabled anyway. When I first installed the software, it initialized the 'scope at COM5, and after I tried another USB port (on a different USB controller) it assigned it to COM6. After all that, I blew out the software and the FTDI drivers, and started anew....that's when it assigned COM4...
The delay in replying is that you posted your message in the Sandbox. As this is a non-Parallax topic forum we don’t put a priority on posts here as they are presumed to be off-topic for our products or at least non-support. Also, your initial post sounded like you just got the scope and never got it to work. Now you indicate that you had it working and something happened. I’m not sure how to interpret “I blew out the software and the FTDI drivers” but I will assume it means you removed them for whatever reason. Nonetheless, since that has happened I would be sure you have the latest driver from the FTDI website. Take care.
Chris Savage
I never did get it to work. When I said "it initialized the 'scope on COM5" I meant Windows assigned COM5 to the device when I plugged it in. The software never did work with it. I should have been more specific about that...as for "I blew out the software and FTDI drivers" that's a casual slang way of saying that I uninstalled the mentioned software from the system, and tried again. I did go and get the latest drivers from FTDI and updated them, but to no avail.
Is there a different method that I should use to seek support on this matter?
Chris Savage
