Better looking mount for dart launcher
I finally finished constructing the new mount for my 12-dart launcher for the Teenage Mutant Ninja Turtle_Bot.· Originally, I just hacked off the rear portion of the truck platform that the dart launcher was attached to·and mounted that to the servo-powered turntable.· (see http://forums.parallax.com/showthread.php?p=676110)
This approach·was problematic both in terms of aesthetics and·construction (it was impossible to access the servo horn screw).· My solution was to cut out two CD-size disks of black Lexan.· The bottom disk is mounted directly to the turntable and has a hole in the middle to allow access to the servo horn screw.· The top disk is attached to the dart launcher and then attached to the bottom disk using four hex standoffs.··Both·Lexan disks are roughly 1" wider than the launcher so there is easy access to standoff hex screws.· Obligatory photos included.
Post Edited (Grievousfish) : 10/1/2007 3:57:51 PM GMT
Have you enjoyed the ARobot?
Whit+
congrats on the first bot!
A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
Removal of the launcher unit is relatively simple. It is just a matter of removing screws and disconnecting a single plug for the two wires that supply the dc motor in the missle launcher. You do not need to take the launcher unit itself apart.
My current program has the launcher firing based on which infrared detector is triggered. It will continue to shoot as long as the detector is triggered but I have the loop limited to 12 cycles (launcher only has 12 darts). Eventually, I will have a program that has both autonomous roaming and IR remote control with dart firing under IR remote control.
I purchased the black turntable that the launcher is attached to from Lynxmotion. It has a servo motor under the housing that allows the turntable to rotate. The dart launcher will pan toward whichever IR detector is being triggered before firing.
I guess I should try to post some video of this thing in operation.
Dg.
