need help w/ 4 servos
I am trying to make this bot work with 4 servos - they are connected to the p12-15 on my BOE (rev c). (using BS2)
p12 Left Front
p13 Left Rear
p14 RightFront
p15 RightRear
I was trying to use the boebot robotics docs as a guide - but then tried adding my extra servos. The rear servos are mounted 180 degrees differently from the front ones - so to get both servos on one side to go the same direction I was sending PULSOUT 650 to right rear and PULSOUT 850 to right front.
I tried for a few hours but never could get it right - and when the program starts, every wheel is turning. When I make changes to the code, it affects that particular servo, but the others continue to spin unless I send a 750 to them.
for example - you would think this would make both wheel turn the same direction
DO
PULSOUT 12, 850
PULSOUT 13, 650
PAUSE 20
LOOP
but this makes the left wheels stop, while the ones on the right keeps turning.
I have centered and tested the servos -
Post Edited (Patrick D) : 9/30/2007 5:21:58 PM GMT
p12 Left Front
p13 Left Rear
p14 RightFront
p15 RightRear
DO
PULSOUT 12, 850
PULSOUT 13, 650
PAUSE 20
LOOP
Your code fragment should make the left front wheel move in one direction and the left rear wheel move in the opposite direction (relative to the motor itself). The way you've mounted them, their wheels should move in the same direction. If they're badly out of adjustment (centering), they could behave the way you describe. Anything else doesn't make sense. You'll need to post your program (as an attachment please) to figure out why it's behaving the way you describe.
What happens when you center and test the servos using the current setup?
I was using an AC power source - and now my BOE is DOA.
