If it's really broke, it can be fixed!
Oldbitcollector (Jeff)
It's almost completely offtopic, but I thought you guys could use a laugh...
My DSL adapter has been on the blink, every time you bump the desk, it would drop out...
So of course I did what any impatient hi-tech redneck would do, picked it up and smacked it on
the desk.. (This actually worked several times) until this afternoon something flew off inside...
One of the coils had a bad solder joint, and my abuse loosened the other side.. <smirk>
After moving the coil to a piece of perfboard, and adding connecting wires I'm back online
and the phone company is sending a new unit..
Moral of the story: If it only works part of the time, break it good so it can be fixed.. <GRIN>
Oldbitcollector
Buttons . . . check. Dials . . . check. Switches . . . check. Little colored lights . . . check.
— Calvin, of 'Calvin and Hobbes.
Oldbitcollector
Brian
uController.com - home of SpinStudio
This should have told you not is all lost when...............every time you bump the desk, it would drop out...
Now have had thing like that happen to before
My Boss at work·had a computer monitor that start to have·only one small line for a picture but if you tapped to top of the monitor, (·I hit a few time my self·) it would come back on for a few days and the same thing would and as time went on it got worst until it·would not come on any more
··········································· ·So what dose·my,·(co worker the REAL hi-tech redneck)
·································································· parts-man73
············································Duct tape is the fix-all. here is an example of what you mean
He take the back of the monitor an put a roll of duck tape under one corner of the circuit board and my Boss ran·it that way for two more weeks until it would not work any more·so when he got the new monitor he ask me if i want it
I said sure let me see if can find where the bad solder joint are and see if i can get it to work again it took me a·few week-en to find where it was now i have a good monitor
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 10/2/2007 12:39:47 AM GMT
A small server(a custom built PC with server software, really) on one of our locations died and would not start again...
I called one of the users at that location, and told him to:
'Stand in front of the server, place your left fist against the side of the server, about 3 inches from the bottom and 5 from the back. Swing it out, then smack it into the server... Now try to switch it on...'
Since then I've had a reputation...
The server had a Vesa(VL-bus) videocard, full-length and all. This card tended to bend a little, and would get misaligned in the socket if the server got bumped around. When the user knocked on the side, the card popped back into place.
Don't visit my new website...
1) If it moves and it ain't s'pose to -- use duct tape.
If it doesn't move and it's s'pose to -- use WD-40.
2) If it's broke use a hammer.
If it still don't work... it needed fixing anyhow.
I'm a half-breed -- half red-neck, half.... sump'in or other.
-Rusty-
Rusty Haddock = AE5AE = rusty@fe2o3.lonestar.org
**Out yonder in the Van Alstyne (TX) Metropolitan Area**
Microsoft is to software what McDonalds is to gourmet cooking
