Making A Pinball Machine
So has anyone tried using parallax products to make a pinball machine?·
The basics are this:
There would be appox 80 switches some optical some mechanical.· You would need to send signals to fire solenoid's around the board.· Probably about 10 to 15 of those.· and then there would be the basic input output to do the scoring and such.
How would you do this with parallax stuff?· Is it too complicated?
I would suggest using any of the faster Parallax processors (like the BS2px or the Propeller) for something like this since the response time, even though based on mechanical operation, is pretty tight. If you're going to use a Stamp, plan on doing the switch contact debouncing using external components like an RC filter.
http://www.users.on.net/~spaners/Coconut Island/
As you can see from their site they are doing alot of the board work out of the keyboard port and other such stuff...
First off, you will likely notice that they go through a lot of light bulbs. So you might want to shift the whole over to LEDs.
And then there is the scoring and display razzle-dazzle. That would be a good place to provide the Propeller. Also a Propeller could provide the special sound effects, but you would need to have an audio amp to crank up the db.
The last thing I would mess with is the electromechanics. Partly because they are well designed and partly because I suspect that there are a lot of voltage spikes that will upset solidstate devices. This area would likely need the most thought to revise.
Have you considered Pachinko as an alternative?
"Everything in the world is purchased by labour; and our passions are the only causes of labor." -- David·Hume (1711-76)········
Question:
Where would you buy all those amazing ball whackers, paddles, ball routers, cellulous star shaped lamps and other fittings?
John Bond
http://www.marcospecialties.com/
http://www.bayareaamusements.com/
On these sites you can pretty much get anything you want on pinball machines. You may also want to check out the google pinball group. There are a ton of experts there working on this stuff. Lastly, if you are looking at some sample electronic diagrams you can go the internet pinball database and often get the manual for a machine. I have a whitewater at home so as an example here is the page for whitewater. If you go about half way down to documentation you can get the whole service manual.
http://www.ipdb.org/search.pl?any=whitewater&search=Search+Database&searchtype=quick
the renge of parts is amazzzing.
John Bond
http://www.happcontrols.com/
There's nothing like a new idea and a warm soldering iron.
John
A while back I started a project to turn my spare PC into an arcade machine using M.A.M.E and this place was great for getting joystick parts and arcade buttons.
Robots essentially rely on electro-mechanical devices to meet the physical world. A lot of what shown is here can extend your robotic creativity.
http://www.kendallvanpool.com/Caploungepinball/
here is my project. Very initial at this point but getting started.
What about a sticky thread about good sources of robotic components in the Robotics forum. Obviously the tread starts with the Parallax electronic stuff then lists the best of the vast list of suppliers of mechanical stuff, motors bearings etc...
...or maybe the forum administrators could consider an additional forum called "resources" or "components" or something that only they (the administrators) can add threads to but that us users can add replies. The posts may for example be "Suppliers of Gears and Bearings" and "Best Posts on Memory" and "Stepper Motors".
We have this amazing group of experts giving their experience freely and I feel that we may be squandering or wasting their knowledge by not recording it.
Greater variety of things we do with Parallax stuff will cause greater enthusiasm which will cause many more users which will cause a greater variety and greater enthusiasm... (Hey I’m getting carried away! You get my drift though.)
And as you all know, satellite Sputnik started the space race 50 years ago yesterday – 4 Oct 1957. What do you mean you don't remember? Didn't you even listen to the "ggg beep gggggg beep gggggg beep" on the radio? Oh I forgot, you’re not an old-timer.
Kind regards
John Bond
http://articles.techrepublic.com.com/5100-10877_11-5995436.html?tag=nl.e064
John
