5 volt regulator
First of all, I just want to say that I am new to the forum. I just bought a 5 volt regulator from Parallax. It is the same type that is on the Basic Stamp Homework Board. I have a 9-volt battery attached to it. When I take my multimeter and read the output voltage, it only brings·the current·down to 7 volts. Why won't it lower it to 5 volts. If you know why, please let me know.
Thanks [noparse]:)[/noparse]
·· Experimenting is good, but it is also important to understand how a component works before implementing it into a circuit. The datasheet will often provide crucial information. In this case, capacitance…the regulators require a certain amount of input/output capacitance to regulate properly. Please be sure to use the appropriate cap on both the input and output and it should work fine. I hope this helps. Take care.
Chris Savage
Parallax Tech Support
- Rick
Minimum load requirements are typical of switching supplies, but the linear regulator is more dependant on having the correct capacitance on the output. Take care.
Chris Savage
Never give up when things go wrong.
robosapienv2-4mem8.page.tl/
Post Edited (StampNut2) : 10/1/2007 5:50:29 PM GMT
http://www.play-hookey.com/analog/experiments/plus_5_volt_ps.html
I love making software [noparse]:)[/noparse]
There's nothing like a new idea and a warm soldering iron.
