Is there a way to COPY information from a DEBUG screen ?
I found some 8x8 character data for my 8x8 LED Matrix project:
http://multilabs.net/Files/ezDISPLAY_Mini_Built-In_Character_Bitmaps.pdf
I can enter the data into my other program in DATA statements but the characters show up reversed or flipped on my display (not 90 degrees off - then I would just rotate the display - but backwards looking). I then went to the BS2 help and found the REV command to reverse bits.
I have attached a short program that reads in the websites 8x8 character map and correct reverses them and displays the information in a DEBUG statement.
I was hoping to just copy this back into my program. However, DEBUG did not let met copy the entry listing.
Is there another way to do this? I don't think I can write this out to a file but there must be an easier way than to have to type the REVersed data back in again. There would be 127 - 32 DATA statments to retype.
Comments? Help.
Comments? Help.
That worked!·I had my commands mixed up·with the Ctl - C when I was Ctl - V ing.
