intercommunications between 2 ProtoBoard with rs232
RE: intercommunications between 2 ProtoBoard with rs232
hi,
for my project, i work on a intercommunications between 2 protoboards
with the FullDuplexSerial-Object, without rs232-hardware, only with
2 cables (rx,tx).
- the master have a vga_text-Object for output.
- the slave have a led on/off - stuff (control for running)
i think, my 2 spin-programms working correctly.
but i have a problem with the transmitting a decimal-value
(x := 1000) from the slave to the master.
what i want:
1) transmit decimal-values from the slave to the master
2) master receive this value and working with this value.
please give me some tips for this problem
thanks
regards
nomad
hi,
2 cables (rx,tx).
what i want:
thanks
regards
nomad
{****************************************************************************** rs232TestMaster_vgaOut_1.spin ******************************************************************************} OBJ ExtSerial : "FullDuplexSerial" ' Full Duplex Serial Controller text : "vga_text" ' Create vgaText-object CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 serRecv = 1 ' Receive on I/O pin 0 = red serXmit = 0 ' Transmit on I/O pin 1 = black VAR BYTE str PUB main | c text.start(16) text.str(string("Serial-InputTest",13,10)) ExtSerial.start(serRecv,serXmit,%0000,9600) ' 9600 Baud repeat 'text.str(string("repeat",13,10)) if(c := ExtSerial.rxtime(500)) => 0 ' Wait up to 500ms for a character 'text.str(string(" Received",13,10)) str := c text.out($0D) ' text.dec(str) waitcnt(30_000_000 + cnt) case c "0".."9": ' do something with a digit "A".."Z","a".."z": ' do something with a letter '13: ' ok, here's a return ' 8: ' backspace key {*************************************************************************** rs232Test_slave_1.spin ----------------------- ***************************************************************************} CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 serRecv = 0 ' Receive on I/O pin 0 serXmit = 1 ' Transmit on I/O pin 1 ledon = 4 VAR BYTE sendbyte OBJ ExtSerial : "FullDuplexSerial" Pub Test1 dira[noparse][[/noparse]ledon]~~ ExtSerial.start(0, 1, 2, 9600) '- rxpin,txpin,mode,Baud ' -1 = receive = read (rxpin) ' 0 = transmission = write (txpin) ' - depends on your set up sendbyte := 125 repeat 1000 ' repeat 5 times !outa[noparse][[/noparse]ledon] 'ExtSerial.tx(sendbyte) ExtSerial.str(string("123",13)) ' old ("A",13,10)) ' \r = for linux carridge return 'waitcnt(100_000_000 + cnt) 'wait a length of time {********************************************************************************************}
ExtSeria.dec(var) should work for what you are trying to do..
Oldbit
Buttons . . . check. Dials . . . check. Switches . . . check. Little colored lights . . . check.
— Calvin, of 'Calvin and Hobbes.
thanks for the tip.
regards
nomad
Best you collect all characters (upto the stop condition, e.g. 13) in a vector, add a zero byte.
and let NUMBERS.fromString(..) do the dirty work
thanks for the tip
today (sunday) i testing the whole stuff
regards
nomad
