Battery question
I have an electronic component that runs off 2 AAA batteries that are connected in parallel. I'd like to extend the battery life, so I'm thinking I could replace the AAA battery power with a battery back that uses a couple of D cell batteries wired in parallel. That should be ok since both AAA and D put out 1.5 volts, right? Many thanks for the sanity check before I power up my hack [noparse]:)[/noparse]
A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
I've never seen this trickyness used for alkaline cells, though.
