pwm power transistor
I am working with a 2amp 12 volt coil that I am trying to control with a pwm, I am using a tip41 power transistor it works good for a moment but after a bit it gets really hot and does not perform like it should I think the gain on it is 15, I have been lead to using a 1k gain transistor would that solve my problem? I've got the diode in the circuit for that back emf. Your advise will be greatly appreciated.
Toby
Toby
thanks
toby
If you're using an NPN power transistor, you've got the transistor connected backwards too. Even if you're using a PNP transistor, the coil shouldn't be in the emitter lead. Before you go any further, please look at the examples in www.parallax.com/dl/docs/prod/sic/Web-PC-v1.0.pdf, chapter 5. Any time you have a solenoid or motor or relay of any size, you will need a diode (like a 1N4001) connected in reverse across the solenoid or relay (so it doesn't normally conduct). This prevents the "back EMF" (generated when the transistor turns off and the coil's magnetic field collapses) from destroying the transistor.
What I am trying to control a 2 amp coil with pwm.
Toby
Thank-You
Since the Stamp can only source or sink about 20mA of current per pin, then I would guess that your transistor is not adequately being driven into saturation.
One suggestion is to find a transistor with a higher hfe of at least·100 or more.· Another is to use an intermediary transistor in a Darlington configuration.
Beau Schwabe
IC Layout Engineer
Your reply will be helpful
Thank You
Toby
Beau Schwabe
IC Layout Engineer
Thank you
Toby
Power = Current * Voltage (P = IV). A 'saturated' transistor (fully on) should have 0.1 volt between Collector and Emitter.
2A * 0.1 Volt == 0.2 watts, or 200 mWatts. 200 milli-watts is a VERY small amount of power to dissapate -- a TO-220 package should be able to disappate 5 watts or so (though it would get quite warm -- 150 degrees or so -- doing it).
Since the TIP41 IS getting hot, it sounds like you haven't 'saturated' it, but instead are operating it in some 'linear' region. Worst case would be it's dropping the entire 5 volts at 2 amps (not sure that's possible, but that WOULD be worst case) which is then 10 watts -- which is a LOT of power to try to dissapate.
So, measure that voltage when it's on, then you'll know how much power it's trying to dissapate. You may have to lower the base resistor on your FIRST transistor, to insure it's puttting enough current into the TIP41 to saturate it.
What is your power supply rating and source to the coil?· If it cannot sustain the required 2A it may allow the TIP41 to fall outside of saturation resulting in excessive heat.
It's also possible that your TIP41 may be damaged from your previous trials.
Beau Schwabe
IC Layout Engineer
There's nothing like a new idea and a warm soldering iron.
My personal preference in a situation like yours would be to use a MOSFET and include a MOSFET driver, if necessary, to increase the switching speed.
Addendum: If you're using the PBASIC PWM command to generate your PWM output, be aware that at 50% duty cycle, you're looking a 113KHz switching frequency. This is much too fast for your switching circuit to keep up with. In general, the PWM command is more suited for producing an analog output though a low-pass filter than for driving inductive loads through saturated switching. Parallax's PWMPAL is one option to consider for a more realistic output frequency. Another would be the MoBoStamp-pe, whose onboard AVRs support PWM output natively.
Post Edited (Phil Pilgrim (PhiPi)) : 9/26/2007 7:37:40 PM GMT
Tobias,
Can you tell us what you are using the PWM'd coil for?
Beau Schwabe
IC Layout Engineer
Thank-You much
Toby
Thank-You
Toby
What you are observing is an average of the PWM, and most of the voltage observed across the transistor should be during the OFF state of the transistor.
Let's back up a minute, and forget about the PWM for a moment to make sure that the transistor is saturating correctly when it is ON.
Your resistance across the Coil is 5.2 Ohms (out of circuit?) and your supply is 12V. Because you are using a bipolar transistor, there is an inherent voltage
drop of about 0.6V ... There is no way around this, that's just how bipolars work, so for the remainder of the bipolar transistor calculations, I will use 11.4V as my supply voltage
instead of 12V. (12V - 0.6V = 11.4V)
The maximum current if the transistor is turned ON should be about 2.2Amps. (I = V/R = 11.4V / 5.2 Ohms = 2.192 Amps)
Now the question is, can your voltage supply handle the demand of 2.192 Amps?
This is also where you should measure the voltage across the transistor, and the Coil.
If the voltage across the transistor is close to 0.6V then we are ok... if it's not then the transistor is not saturated, and you will develop a LARGE amount of heat.
To see this, consider the 0.6V that should be across the transistor. Remember, the same amount of current is going through the transistor as is the coil.
Power or Watts = I * V =·2.192 * 0.6V·= 1.3 Watts ... That's a fair amount, and that's an ideal circumstance.
Now, suppose the transistor was reading 1.1V ... The same formula would apply...
Power or Watts = I * V =·2.192 * 1.1V··= 2.4 Watts ... That's HUGE amount of difference for only a half of a volt change!
For a MOSFET solution, what you look for is a low RdsON (<- which means ... A low Resistance across the Source and Drain while the transistor is ON)
With a MOSFET, you don't have a 0.6V drop.
Suppose you have a MOSFET with an RdsON of .055 Ohms ... To calculate maximum current, the equation would look like...
I = V / (Rcoil + Rmosfet) = 12V / 5.255 Ohms = 2.284 Amps
Now, this seems like it's going the wrong way because you now have a higher current, but look what is happening across the MOSFET.
Power or Wattage = I^2 * R = 5.217 * 0.055 Ohms = 287mW .... Compare that to the bipolar transistor at 1300mW
Less energy is being wasted as heat, and more energy is available across·your coil.
Bottom line is....
1) Make sure that your power supply can handle the current demand regardless of what transistor type you are using.
2) If you are using a bipolar transistor, make sure it is properly saturated
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 9/28/2007 3:18:09 PM GMT
My 2 cents
Marty
Lunch cures all problems! have you had lunch?
