DLP Prop board doesn't work without USB host?
Among other boards I have a DLP Designs 'DLP Prop' which is a bit like a PropStick. I think I must be doing something wrong because I just can't get it to work without a USB connection to a host. I powered it from a 7805 5V regulator but no luck. Does it do nothing until it has communicated it's USB ID or is it some simple power thing I just don't get? Can it be made to work stand-alone? Perhaps the FTDI USB USART thang can be tweaked? I feel that there must be a document·I haven't found which explains it all.
I could not get a response from the manufacturers and I don't want to waste it so -·if anyone has·succeeded with this I would be grateful for advice.
Miles
Miles
The DLP-Prop was designed to remained connected to a host PC.· The clock for the Propeller is taken from the USB IC which goes to Standby mode when the 1mS frames from the host stop.
If you want to operate without the host connected then you will have to enable the internal oscillator in the Propeller and apply your own 3.3V power supply to the SW33V pin (pin 17).
Also, its best to not have your 3.3V supply connected while also connected to the host PC so you are not driving the output of the 3.3V regulator.
Don
Rgds
Miles
_clkmode = RCFAST
Try this listing:
'' Propeller "Hello, World!" demo
'' -- blink an LED on pin A27
'' A27>───────┐
'' 330Ω
CON
_clkmode = RCFAST ' use internal osc
Led = 27
VAR
long delayTime ' used for delay
PUB BlinkLED
dira[noparse][[/noparse]Led] := 1 ' make the pin an output
repeat
outa[noparse][[/noparse]Led] := !outa[noparse][[/noparse]Led] ' toggle the pin state
delayTime := cnt + 8_000_000 ' delay = 8 million cycles
waitcnt(delayTime) ' wait
I hoped it would be something like that. That is very easy.
I like the DLP Prop now.
Thankyou again.
Rgds
Miles
Graham
I'm very glad I did not buy a DLP-Prop as it would not have delivered what I expected.
Maybe some circuit surgery is in order to take the XIN to an external leg and drive that from an external oscillator module ?
Don, I've had several issues with the DLP Prop but the main one was that the clock out of the FTDI chip is ~6MHz and fluctuates all over the place.
Is this norma?l It makes the device useless for video work!
Or do I just have a faulty device?
Coley
Graham
"... one of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs." -
"If Python is executable pseudocode, then perl is executable line noise."
"The best accelerator available for a Mac is one that causes it to go at 9.81 m/s2."
"My software never has bugs. It just develops random features."
"Windows isn't a virus, viruses do something."
"Programmers are tools for converting caffeine into code."
"Enter any 11-digit prime number to continue."
I must admit I'd given up all hope on it lol
Coley
