internal pullup resister
I m using this circuit for sensor reading.is it possible to use internal· pullup resistor of sx48 and not use 10k resistor on attachment
Post Edited (AHMET AKSU) : 9/25/2007 1:06:59 PM GMT
Bean.
I know what I know, don't confuse me with the facts...
www.hittconsulting.com
Bean
http://www.parallax.com/detail.asp?product_id=27925
I would like to use my uLCD-320-PMD2 display with an SX-28 and it would be convient to use SX/B internal pull up coding·versus actual external 10K resistors.
https://www.littlepcbsolutions.com/uLCD-320-PMD2.html
Do you think this would be ok? Is there any test I can do to check to see if they are needed or can use the internal pull up coding?
However, recently I saw on another posting that 4.7K resistors should be used on serial data lines like this.
Comments?
The smaller value resistor, the more current is used when the line is pulled low, but the faster the rise time.
On most things it doesn't really matter that much. 4.7K, 10K, 20K
If you have problems with communication, try a lower value.
Bean.
