RoboGames Scrolling LED Medal - Available For A Limited Time
RoboGames Scrolling LED Medal·(#28099)·- Available for a Limited Time
Parallax sponsored the 2007 RoboGames by designing the awards for contest winners. The award is an SX28-controlled array of three 5 x 7 red dot-matrix LEDs side-by-side.
The Medal uses the SX/B compiler for the SX28AC/SS microcontroller. The SX/B compiler makes it a snap to customize the displays by simply changing one line of code which stores the character string in the SX’s EEPROM. The code examples are available for download.
The considerations towards programming the RoboGames medal for your own use are that you need an SX-Key and a 5V power supply. The Medal requires two RL123A batteries (Not Included), but only 4.5V and 5V are required for programming SX chips. The SX-Key is available in our SX Tech Tool Kit PLUS.
For more information, or to purchase the RoboGames Scrolling LED Medal, visit http://www.parallax.com/detail.asp?product_id=28099.
Lauren Davis
Marketing Manager
916-624-8333
ldavis@parallax.com
Lauren Davis
Marketing Manager
916-624-8333
ldavis@parallax.com
Robolympics winners received them in Gold, Silver and Bronze (no blue).
The batteries are CR123s. We are selling them for less than $3 each. Don't buy them at a drug store - you'll pay too much. We've tested every major brand on the market and the Rayovac has 95% of the amp-hour capacity of an Energizer with 200 mA current draw. In fact, it performs better than an $8.00 Duracell!
I compiled the programs (Badge and RobOlyCodeSXB151) and now nothing works. Being the slow-witted person I am, I sort of need a walkthrough on what I should be doing to get this thing up and running.
I had connected my SX-Key directly to the medal and it seemed to take the program okay. No barking from the IDE. But I am left with a device that doesn't make a sound or show a light.
Can you help this old man?
Joss
First install the SX software and download the two sample programs for the medal, and then this update (right below the product listing) to have version 1.51 of the programming environment:
SX/B Update - SX/B version 1.51(.zip 200KB) [noparse][[/noparse]Dated: 07/24/06]
found here:
http://www.parallax.com/sx/sxb.asp
Then proceed as follows:
Hook up the medal with the SX key circuit side up. Turn the medal on (batteries installed) Use a USB to serial adapter to the USB port on your computer. Load any of the two program listings on the Parallax site (below the product), and open it in the SX-Key v3.2 application. I recomed the program they used for the robolympics (RobOlyCodeSXB151.SXB). Change the text that prints the scroll text. Comment out the line of code as I did below (its near the beginning):
'IRC_CAL IRC_4MHZ This is the line I commented out (see the fist character of this line)
change this line as I did for it to say what you want, like this for example:
Data " Je m'appelle Brandon Reznicek, j'ai 10 ans et mon pere c'est un Dork. ",0
(I wrote this in French for my son)
Select "Run", and watch it program the medal
Done!
Ask me if you need more help. -Migs
"Sometimes we forget that the world itself is paradise." Douglas Coupland, 'Microserfs'
"If the doors of perception were cleansed every thing would appear to man as it is, infinite" - William Blake
"We either make ourselves miserable, or we make ourselves strong. The amount of work is the same." Carlos Castaneda
"One single grateful thought raised to heaven is the most perfect prayer. " G. E. Lessing
“How much of human life is lost in waiting.” Ralph Waldo Emerson
"Men often mistake notoriety for fame, and would rather be remembered for their vices and follies than not be noticed at all.” Harry Truman
My website: www.intoku.net my e-mail:mreznicek@pretensa.com me:Miguel Reznicek
Post Edited (Migs) : 7/20/2007 2:58:37 AM GMT
Thank you!
It worked like a charm.
I need to look up that value on the line you had me comment out.
The other difference was that I was going through a straight com connection instead of USB to RS-232. I'll try that again.
Much appreciation to you!
Joss
Thanks.
Post Edited (T&E Engineer) : 8/29/2007 1:48:10 PM GMT
Does anyone know where to get the rings to put arund the medal, which frame it and allow it to be hung?
Migs
At power-up (and every 5 minutes) it will display "Ask me a question...". Pressing the reset button displays a random response.
Bean.
I know what I know, don't confuse me with the facts...
www.hittconsulting.com
I think the problem is that you are looking at the pin connections for a DIP version of the SX-28, whereas the Robo-Medal uses the SMD version which has a different pin out. I also noticed your corrections refer specifically to the PDB which uses the DIP version. Unless there is something else I am missing or some other detail I have to assume our schematic is, in fact, correct. Please, let me know exactly which pins are in the incorrect locations for clarity.
Note: I am cross-posting this (against our own guidelines) so that both threads are addressed.
Chris Savage
Parallax Tech Support
Thanks for catching this Chris!
Post Edited (kf4ixm) : 2/17/2010 3:48:47 AM GMT
Bean
Use BASIC on the Propeller with the speed of assembly language.
PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
March 2010 Nuts and Volts article·http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp5.pdf
http://forums.parallax.com/showthread.php?p=670557
Attached you will also find the code (in the link also). All you should have to do is look for the CONSTANT (CON):
MsgLen··CON·40 '15···' Message Length
MsgLenMinus1·CON·39
MsgLenPlus1·CON·41
Where you see the commented numbers (e.g. 15) this was the original value I beleive. Look through the code and replace the 40 with the 15 and follow suite for the Minus1 and Plus1 CON useage.
I know I have the original on my home computer but not at the moment at work. If I find the originals I will also post again.
I do know that·JonnyMac's original code was·far superior (more graphics and scrolling effects) than the original Parallax code and·his code·is·called something like Badge.sxb
Thank you very much!
i have one more question for either one of you (or anyone else for that matter). in the data area, for the fonts, if i wanted to change the font to be more compressed, say like:
DATA %00111110 ' C
DATA %01000001
DATA %01000001
DATA %01000001
DATA %00100010
To like:
DATA %00111110 ' C
DATA %01000001
DATA %01000001
DATA %00100010
would i just have to change that data string in all the characters, or would i have to something else also in the way it scrolls the data? i found the badge.sbx code, thats the one im using.
That's right. Now you will have a font that is 4x7 (or really 4x7 because the last bit is 0).
I have attached the 2 RobOlympic code programs also.
Post Edited (kf4ixm) : 3/2/2010 2:03:43 PM GMT
Let us know if this fits your needs.
Parallax Inc.
Follow me at http://twitter.com/ParallaxKen for some insider news.
Thanks again!
Parallax Inc.
http://forums.parallax.com/showthread.php?p=886745
Post Edited (kf4ixm) : 3/3/2010 6:39:51 PM GMT
