Looking for an ADC — Parallax Forums
Looking for an ADC
NewzedNewzed Posts: 2,503
edited 2007-09-24 01:30 in General Discussion
I was looking for a small ADC and came up with the MCP3004 - 10-bit, 4 channel, SPI interface.· Anyone have a better suggestion.\?· Would like to stay with the SPI interface because I understand the shiftin/shiftout stuff.
Sid
Yesterday is history, tomorrow is a mystery, and today is a gift.
That is why they call it the present.
Don't have VGA?
Newzed@aol.com
  • MarkSMarkS Posts: 342
    edited 2007-09-22 00:19
  • NewzedNewzed Posts: 2,503
    edited 2007-09-22 00:25
    Nice chip, Mark, but I don't have that much room.· Besides, its for the Propeller and I would prefer one that operates from 3 VDC.· Thanks anyway.
    Sid
    Don't have VGA?
    Newzed@aol.com
    edited 2007-09-22 02:16
    The dual version of the MCP3004 is what I've been looking at for the MoBoProp motherboard. It seems like a good match to the Propeller and should be able to sustain about 90K samples/sec at 3.3V (interpolated from specs).
    edited 2007-09-22 12:01
    Phil, do you have an example of the shiftin and shiftout statements?· With the TLC2543 I write:
    LOW cs
    SHIFTOUT dout, clk, msbfirst, [noparse][[/noparse]ADch<<8\12]
    SHIFTIN din, clk, msbpre, [noparse][[/noparse]result\12]
    HIGH cs
    What would I write for the MCP3004?
    Sid
    Don't have VGA?
    Newzed@aol.com
    edited 2007-09-22 13:44
    Phil, I had a small design problem with the MCP3004.· I'd love to run it with 3.3VDC, but since most sensors, particularly the LM34, need 5VDC, I had to run the 3004 at 5VDC.· I added a 4.7K SMD 0805 in series with the Dout pin to the Prop so that should solve matters.
    Sid
    Don't have VGA?
    Newzed@aol.com
    edited 2007-09-22 18:21
    I just used an ADS1000 in SOT23-6 package for a project where the ADC had to be right next to the measurement point. It is single channel differential, 12 bit, with a built in PGA, but it is I2C, not SPI. The ADS1100 is a pin compatible 16 bit converter.
    Tracy Allen
    www.emesystems.com
    edited 2007-09-23 14:36
    Phil, I'm making a board for an MCP3004 module on SuperMill so I can test it out before I incorporate it into a board.· The board will plug into either the Stamp or the Propeller and runs off 5VDC.· Would you like a board?· They are no trouble to make.· No charge, of course.
    Sid
    Don't have VGA?
    Newzed@aol.com
    Sid,
    Sure! I'd like to see one of your milled boards. I'll email my postal address pronto.
    Thanks!
    Phil
