MULTIPLE HB-25`s one BS2p poor performance
Hello everybody,
·I`ve been working on a project which requires the use of nine HB-25`s. Everytime I try to hook up more than four HB-25`s, I get strange behavior, or no reaction at all from #5·thru #9. I think the problem is that the stamp can`t handle the current draw from the HB-25`s. Currently , I am thinking of using multiple BS2p`s in a Master/Slave type of configuration to lighten the load. It would be nice to control all 9· HB-25`s with a single BS2p , but if I can`t , the second option seems like it may give me more flexibility down the road. My plan is to add many types of sensors. I was wondering if anyone out there has any ideas on this problem.
Ken
Ken
- Stephen
Ken
Ken
- Stephen
An idle HB-25 draws 50-80ma. Four of these only draw 200-240ma and the BS2p draws around 40ma for a total under 300ma. That's not much. What are your motors drawing? The LM338Ks will handle about 10A. Will your unregulated supply provide that much?
I am building a "JOHNNY 5" type of robot. Most of the parts are from an automotive junk yard. Each of the robots arms has a SPAL 12V actuator for shoulder operation. I measured the current draw at about 75mA no load for each one. The bicepts have windshield wiper motors. Each one draws 3.3 amps, no load. The elbow motors are from Buehler. They draw 170mA, no load. The forearms also use Buehlers The final HB25 powers the waist pivot. Each arm also has 4 powerful hitec HSR-5995-TG for the wrists and " fingers ". They are on a different system ( parallax servo controller ). I am trying to keep the entire project as compact as possible. I know that eventurally, I will have to use " slave " stamps , but for now it would simplify everything to put all 9 HB25`s on one Stamp.
So , what do you think I should do ?
Ken
Post Edited (Mike Green) : 9/22/2007 6:32:33 AM GMT
Two totally separate 24V battery systems , one primary , and one back up,( 2 ,12V,18amp and 4, 6V,4.5amp ). These systems power 2 wheel chair motors and their separate Victor 883 speed controllers.
Two 12V systems, for the HB25`s , primary (one 12V, 38amp battery), and a back up ( 2, 6V, 12amp batteries)
Servos are powered by a separate 7.2V NiMH battery pack.
I failed to mention this earlier, but when I tried to hook up HB25 # 5, the battery almost shorted out, and the motor got really hot.
As I mentioned above all logic is powered from a separate power source. Their is no common ground. All systems are totally isolated. so if I
am reading you right , your saying that I should connect all systems to a common ground , yes ?
The HB-25 takes care of this by providing a logic ground (Vss) terminal on the "servo" cable. This is (has to be) connected to the logic ground. The Victor controller's PWM cable also has a logic ground. If you've connected these properly (with the black or Vss wire connected to the BS2p's Vss terminal), you'll have a common logic ground. Similarly, the black lead for the servos has to be connected to the BS2p's Vss terminal as well as the NiMH battery ground.
There must be something about how you've got things hooked up that's causing the problem and there's not enough detail in your description to sort that out. You'll have to post a schematic. If you don't have a schematic, make one, then post it. Often the process of writing everything down in detail will help you find out what's connected wrong.
The Victors and their SSC-II ,can be programed or operated remotely with the futaba 9CAP. The PSC and it`s BS2p control the servos flawlessly, but I digress. What I`m trying to convey to you is that I`ve had plenty of experiance with these systems but always through an interface which was purchased. I was doing great until I tried to connect that fifth HB-25.
I will take your advice and back track through the whole system.It may take a few days but maybe there is a bad ground connection some where.
PS. You seem to know about victors. Their controllers are also known to draw alot of current. They solve this problem with booster cables
which can be purchased from IFI. Since I have extra cables I was going to try it on the HB-25. But again, I digress I will take the system apart.
Ken
Never give up when things go wrong.
robosapienv2-4mem8.page.tl/
