SX48 pins
Hi, I met a problem once I am using the DLP-245SY-G which uses the SX48 controller. Actually I am using the application TOKEN 245SY.
Every time, when I read or write the Port B, C, E, the Port D databus will go HIGH. What's the link between Port D with other Ports?
I don't know is the problem relating to the SX48 chip or not?
Thanks.
Thanks.
I looked on Mouser's website at the board and it mentions shipping with sample code installed that enables the SX48 to communicate with the USB driver.
This could be causing the issue.
Do you have, or can you get a copy of the code that comes installed on the device?
I wonder if this wire is hot...
void main()
//1111 1100 port A idle state: 7654 3210 1=input 0=output
ddra = 0xfc;
asm(mov w,ddra); asm(mov !porta,w );
//1000 1111 port B idle state: 7654 3210 1=input 0=output
ddrb = 0x8f;
asm(mov w,ddrb); asm(mov !portb,w );
//0011 0000 port C idle state: 7654 3210 1=input 0=output
ddrc = 0xff;
asm(mov w,ddrc); asm(mov !portc,w);
SETPORTDIN;//make port d all input
//1111 1111 port E idle state: 7654 3210 1=input 0=output
ddre = 0xff;
asm(mov w,ddre); asm(mov !porte,w );
//init USB and LED
asm(setb porta.0);//take RD high
asm(setb porta.1);//take WR high
asm(setb portb.4);//take SND high
asm(clrb portb.5);//turn led on
asm(clr !wdt);//pet the dog
delay_msec(200);//power up delay
asm(mov w,porta); asm(mov tt,w); tt &= 0x08;//read RXF
if(tt==0)//purge USB FIFO
asm(clrb porta.0);//take RD low
//FLASH LED
for(tt=0; tt<10; tt++)
asm(setb portb.5);
delay_msec(40);
asm(clrb portb.5);
delay_msec(40);
led_count=0;
led_count1=0;
while(1)
toggle_led();
//byte received in FIFO buffer...
asm(mov w,porta); asm(mov tt,w); tt &= 0x08; //read RXF
if(tt==0)
receive_packet();
mptr = &buffer;
mptr++;
cmd = *mptr;
*mptr=0;
switch(cmd)
case 0xA7: //if Return Board ID command...
send('2');
send('4');
send('5');
send('S');
send('Y');
strobe_SND();//send now
cmd = 0;
break;
case 0xAF: //if Loopback test
send(buffer);
cmd = 0;
break;
case 0xAA: //if EEPROM Read
tmp = ee_read(0xA1, buffer);
send(tmp);
cmd = 0;
break;
case 0xAB: //if EEPROM Write
ee_write(0xA0, buffer, buffer);
cmd = 0;
break;
case 0xAC: //if temperature start convert command
d_pin = buffer;
D_Reset();
if(D_Error < 99)
send(D_Error);//return error
cmd=0;
break;
else
send(0x63);//return no error (99)
Write_byte(0xcc);//skip rom command
Write_byte(0x44);//Convert temperatures
cmd = 0;
break;
case 0xAD: //if temperature read command -
d_pin = buffer;
D_Reset();
Write_byte(0xbe);//read scratch pad
delay_usec(5);
for(tt=0; tt<9; tt++)
tmp = Read_byte();
send(tmp);
cmd = 0;
break;
case 0x57: //if Port B read
//11001111 keep some output
ddrb = 0xcf;//make port b partial input
send( portb );
cmd = 0;
break;
case 0x58: //if Port B write
//11010000 leave EE data as input
ddrb = 0xD0;//make port b partial output
portb = buffer;
cmd = 0;
break;
case 0x59: //if Port C read
ddrc = 0xff;//make port c all input
asm(mov w,ddrc); asm(mov !portc,w );
send( portc );
cmd = 0;
break;
case 0x5A: //if Port C write
ddrc = 0x0;//make port c all output
portc = buffer;
cmd = 0;
break;
case 0x5B: //if Port D read
ddrd = 0xff;//make port d all input
asm(mov w,ddrd); asm(mov !portd,w );
send( portd );
cmd = 0;
break;
case 0x5C://if Port D write
ddrd = 0x0;//make port d all output
portd = buffer;
cmd = 0;
break;
case 0x5D: //if Port E read
ddre = 0xff;//make port e all input
send( porte );
cmd = 0;
break;
case 0x5E: //if Port E write
ddre = 0x0;//make port e all output
porte = buffer;
cmd = 0;
break;
case 0xA5: //if Line in command...
databit = get_portpin(buffer);
send(databit);
cmd = 0;
break;
case 0xA6: //if Line out command...
portpin_hilow(buffer, buffer);
cmd = 0;
break;
}//end of Switch()
}//end of if(tt==16)
}//end of while(1)
}//end of main()
void receive_packet()
rptr = &buffer;
for(pn=0; pn<10; pn++)
*rptr = 0xcc;
rptr++;
num_bytes=read_usb();//get the number of bytes
buffer[noparse][[/noparse]0]=num_bytes;
save_bytes = num_bytes;//save a copy
pos=1;
rptr = &buffer;
while(num_bytes--)
rptr++;
empty=1;
while(empty)//wait for the next byte to arrive
asm(mov w,porta); asm(mov empty,w); empty &= 0x08; //read RXF
pn = read_usb();
*rptr = pn;
checksum=0;
rptr = &buffer;
for(pn=0; pn<save_bytes+1; pn++)
pos = *rptr;
checksum = checksum ^ pos;
rptr++;
empty=1;
if(read_usb() == checksum)//if checksums match
delay_msec(5);
if(empty==0)//if more data in FIFO
//still have data in the FIFO -- ERROR!
delay_msec(5);
while(empty==0)//clear the FIFO
delay_msec(5);
read_usb();
send(0xAb);//error!
packet_ready=0;
else
send(0x55);//no error
delay_msec(5);
packet_ready=1;
else//checksum failed
send(0xaa);//error!
packet_ready=0;
toggle_led()
led_count1++;
if(led_count1 < 5)
return;
led_count1=0;
led_count++;
rr=50000;
if(led_count > rr)
led_count=0;
//toggle LED
if(led_state==0)
led_state=1;
asm(clrb portb.5);
else
led_state=0;
asm(setb portb.5);
int get_portpin(int port_pin)
switch(port_pin)
case 0xB0: asm(setb ddrb.0); asm(mov w,ddrb); asm(mov !portb,w );
asm(mov w,portb.0); asm(mov indata,w);
break;
case 0xB1: asm(setb ddrb.1); asm(mov w,ddrb); asm(mov !portb,w );
asm(mov w,portb.1); asm(mov indata,w); indata >>=1;
break;
case 0xB2: asm(setb ddrb.2); asm(mov w,ddrb); asm(mov !portb,w );
asm(mov w,portb.2); asm(mov indata,w); indata >>=2;
break;
case 0xB3: asm(setb ddrb.3); asm(mov w,ddrb); asm(mov !portb,w );
asm(mov w,portb.3); asm(mov indata,w); indata >>=3;
break;
case 0xC0: asm(setb ddrc.0); asm(mov w,ddrc); asm(mov !portc,w );
asm(mov w,portc.0); asm(mov indata,w);
break;
case 0xC1: asm(setb ddrc.1); asm(mov w,ddrc); asm(mov !portc,w );
asm(mov w,portc.1); asm(mov indata,w); indata >>=1;
break;
case 0xC2: asm(setb ddrc.2); asm(mov w,ddrc); asm(mov !portc,w );
asm(mov w,portc.2); asm(mov indata,w); indata >>=2;
break;
case 0xC3: asm(setb ddrc.3); asm(mov w,ddrc); asm(mov !portc,w );
asm(mov w,portc.3); asm(mov indata,w); indata >>=3;
break;
case 0xC4: asm(setb ddrc.4); asm(mov w,ddrc); asm(mov !portc,w );
asm(mov w,portc.4); asm(mov indata,w); indata >>=4;
break;
case 0xC5: asm(setb ddrc.5); asm(mov w,ddrc); asm(mov !portc,w );
asm(mov w,portc.5); asm(mov indata,w); indata >>=5;
break;
case 0xC6: asm(setb ddrc.6); asm(mov w,ddrc); asm(mov !portc,w );
asm(mov w,portc.6); asm(mov indata,w); indata >>=6;
break;
case 0xC7: asm(setb ddrc.7); asm(mov w,ddrc); asm(mov !portc,w );
asm(mov w,portc.7); asm(mov indata,w); indata >>=7;
break;
case 0xD0: asm(setb ddrd.0); asm(mov w,ddrd); asm(mov !portd,w );
asm(mov w,portd.0); asm(mov indata,w);
break;
case 0xD1: asm(setb ddrd.1); asm(mov w,ddrd); asm(mov !portd,w );
asm(mov w,portd.1); asm(mov indata,w); indata >>=1;
break;
case 0xD2: asm(setb ddrd.2); asm(mov w,ddrd); asm(mov !portd,w );
asm(mov w,portd.2); asm(mov indata,w); indata >>=2;
break;
case 0xD3: asm(setb ddrd.3); asm(mov w,ddrd); asm(mov !portd,w );
asm(mov w,portd.3); asm(mov indata,w); indata >>=3;
break;
case 0xD4: asm(setb ddrd.4); asm(mov w,ddrd); asm(mov !portd,w );
asm(mov w,portd.4); asm(mov indata,w); indata >>=4;
break;
case 0xD5: asm(setb ddrd.5); asm(mov w,ddrd); asm(mov !portd,w );
asm(mov w,portd.5); asm(mov indata,w); indata >>=5;
break;
case 0xD6: asm(setb ddrd.6); asm(mov w,ddrd); asm(mov !portd,w );
asm(mov w,portd.6); asm(mov indata,w); indata >>=6;
break;
case 0xD7: asm(setb ddrd.7); asm(mov w,ddrd); asm(mov !portd,w );
asm(mov w,portd.7); asm(mov indata,w); indata >>=7;
break;
case 0xE0: asm(setb ddre.0); asm(mov w,ddre); asm(mov !porte,w );
asm(mov w,porte.0); asm(mov indata,w);
break;
case 0xE1: asm(setb ddre.1); asm(mov w,ddre); asm(mov !porte,w );
asm(mov w,porte.1); asm(mov indata,w); indata >>=1;
break;
case 0xE2: asm(setb ddre.2); asm(mov w,ddre); asm(mov !porte,w );
asm(mov w,porte.2); asm(mov indata,w); indata >>=2;
break;
case 0xE3: asm(setb ddre.3); asm(mov w,ddre); asm(mov !porte,w );
asm(mov w,porte.3); asm(mov indata,w); indata >>=3;
break;
case 0xE4: asm(setb ddre.4); asm(mov w,ddre); asm(mov !porte,w );
asm(mov w,porte.4); asm(mov indata,w); indata >>=4;
break;
case 0xE5: asm(setb ddre.5); asm(mov w,ddre); asm(mov !porte,w );
asm(mov w,porte.5); asm(mov indata,w); indata >>=5;
break;
case 0xE6: asm(setb ddre.6); asm(mov w,ddre); asm(mov !porte,w );
asm(mov w,porte.6); asm(mov indata,w); indata >>=6;
break;
case 0xE7: asm(setb ddre.7); asm(mov w,ddre); asm(mov !porte,w );
asm(mov w,porte.7); asm(mov indata,w); indata >>=7;
break;
indata &= 1;
return indata;
void portpin_hilow(int port_pin, int hilow)
switch(port_pin)
case 0xB0: asm(clrb ddrb.0); asm(mov w,ddrb); asm(mov !portb,w );
if(hilow) asm(setb portb.0); else asm(clrb portb.0);
break;
case 0xB1: asm(clrb ddrb.1); asm(mov w,ddrb); asm(mov !portb,w );
if(hilow) asm(setb portb.1); else asm(clrb portb.1);
break;
case 0xB2: asm(clrb ddrb.2); asm(mov w,ddrb); asm(mov !portb,w );
if(hilow) asm(setb portb.2); else asm(clrb portb.2);
break;
case 0xB3: asm(clrb ddrb.3); asm(mov w,ddrb); asm(mov !portb,w );
if(hilow) asm(setb portb.3); else asm(clrb portb.3);
break;
case 0xB5: asm(clrb ddrb.5); asm(mov w,ddrb); asm(mov !portb,w );
if(hilow) asm(setb portb.5); else asm(clrb portb.5);
break;
case 0xC0: asm(clrb ddrc.0); asm(mov w,ddrc); asm(mov !portc,w );
if(hilow) asm(setb portc.0); else asm(clrb portc.0);
break;
case 0xC1: asm(clrb ddrc.1); asm(mov w,ddrc); asm(mov !portc,w );
if(hilow) asm(setb portc.1); else asm(clrb portc.1);
break;
case 0xC2: asm(clrb ddrc.2); asm(mov w,ddrc); asm(mov !portc,w );
if(hilow) asm(setb portc.2); else asm(clrb portc.2);
break;
case 0xC3: asm(clrb ddrc.3); asm(mov w,ddrc); asm(mov !portc,w );
if(hilow) asm(setb portc.3); else asm(clrb portc.3);
break;
case 0xC4: asm(clrb ddrc.4); asm(mov w,ddrc); asm(mov !portc,w );
if(hilow) asm(setb portc.4); else asm(clrb portc.4);
break;
case 0xC5: asm(clrb ddrc.5); asm(mov w,ddrc); asm(mov !portc,w );
if(hilow) asm(setb portc.5); else asm(clrb portc.5);
break;
case 0xC6: asm(clrb ddrc.6); asm(mov w,ddrc); asm(mov !portc,w );
if(hilow) asm(setb portc.6); else asm(clrb portc.6);
break;
case 0xC7: asm(clrb ddrc.7); asm(mov w,ddrc); asm(mov !portc,w );
if(hilow) asm(setb portc.7); else asm(clrb portc.7);
break;
case 0xD0: asm(clrb ddrd.0); asm(mov w,ddrd); asm(mov !portd,w );
if(hilow) asm(setb portd.0); else asm(clrb portd.0);
break;
case 0xD1: asm(clrb ddrd.1); asm(mov w,ddrd); asm(mov !portd,w );
if(hilow) asm(setb portd.1); else asm(clrb portd.1);
break;
case 0xD2: asm(clrb ddrd.2); asm(mov w,ddrd); asm(mov !portd,w );
if(hilow) asm(setb portd.2); else asm(clrb portd.2);
break;
case 0xD3: asm(clrb ddrd.3); asm(mov w,ddrd); asm(mov !portd,w );
if(hilow) asm(setb portd.3); else asm(clrb portd.3);
break;
case 0xD4: asm(clrb ddrd.4); asm(mov w,ddrd); asm(mov !portd,w );
if(hilow) asm(setb portd.4); else asm(clrb portd.4);
break;
case 0xD5: asm(clrb ddrd.5); asm(mov w,ddrd); asm(mov !portd,w );
if(hilow) asm(setb portd.5); else asm(clrb portd.5);
break;
case 0xD6: asm(clrb ddrd.6); asm(mov w,ddrd); asm(mov !portd,w );
if(hilow) asm(setb portd.6); else asm(clrb portd.6);
break;
case 0xD7: asm(clrb ddrd.7); asm(mov w,ddrd); asm(mov !portd,w );
if(hilow) asm(setb portd.7); else asm(clrb portd.7);
break;
case 0xE0: asm(clrb ddre.0); asm(mov w,ddre); asm(mov !porte,w );
if(hilow) asm(setb porte.0); else asm(clrb porte.0);
break;
case 0xE1: asm(clrb ddre.1); asm(mov w,ddre); asm(mov !porte,w );
if(hilow) asm(setb porte.1); else asm(clrb porte.1);
break;
case 0xE2: asm(clrb ddre.2); asm(mov w,ddre); asm(mov !porte,w );
if(hilow) asm(setb porte.2); else asm(clrb porte.2);
break;
case 0xE3: asm(clrb ddre.3); asm(mov w,ddre); asm(mov !porte,w );
if(hilow) asm(setb porte.3); else asm(clrb porte.3);
break;
case 0xE4: asm(clrb ddre.4); asm(mov w,ddre); asm(mov !porte,w );
if(hilow) asm(setb porte.4); else asm(clrb porte.4);
break;
case 0xE5: asm(clrb ddre.5); asm(mov w,ddre); asm(mov !porte,w );
if(hilow) asm(setb porte.5); else asm(clrb porte.5);
break;
case 0xE6: asm(clrb ddre.6); asm(mov w,ddre); asm(mov !porte,w );
if(hilow) asm(setb porte.6); else asm(clrb porte.6);
break;
case 0xE7: asm(clrb ddre.7); asm(mov w,ddre); asm(mov !porte,w );
if(hilow) asm(setb porte.7); else asm(clrb porte.7);
break;
//Read a byte from the DS18S20
unsigned int Read_byte()
unsigned int data;
int count;
data=0;
for(count=8; count>0; count--)
//Write the bit to the port
portpin_hilow(d_pin, 0);
delay_usec(2);
//Release port for reading
get_portpin(d_pin);
//delay to center of timeslot
delay_usec(10);
//Read the data bit in
D_Data=get_portpin(d_pin);
//Finish the timeslot
delay_usec(60);
//Put data into the byte
data = data >> 1; //Shift previous bits across
if(D_Data==1) //If data was high then add high bit to data
data +=0x80;
//Delay Between Bits
delay_usec(10);
//rise time plus min space
delay_usec(10);
return(data);
void D_Reset() //Reset the DS18S20
int count;
D_Error=99; //-- Reset the status bit to no error
get_portpin(d_pin);
//Start the reset Pulse
delay_usec(80);
delay_usec(200);
delay_usec(200);
//release the line
get_portpin(d_pin);
//delay to about the center of the presence pulse
delay_usec(90);
//get presence status 1=fail 0=present
D_Presence = get_portpin(d_pin);
delay_usec(100);
delay_usec(200);
D_SC = get_portpin(d_pin);//check for short circuit
if(D_SC == 0) //if short circuit then error
D_Error = 8;
if(D_Presence == 1) //if no device detected then error
D_Error = 2;
delay_usec(10);
void Write_byte(int Data)//write a byte to the DS18S20
int count;
D_Data= Data & 0x01; //LSB
//write the bit to the port
delay_usec(4); //time slot start
//write data to the port
if(D_Data)
get_portpin(d_pin);//input (pulled high)
else
portpin_hilow(d_pin, 0);//driven low
delay_usec(66);
//release port pin
get_portpin(d_pin);
delay_usec(10);
Data>>=1; //shift next bit into place
delay_usec(10);
void strobe_SND()
asm(clrb portb.4);
asm(nop);
asm(nop);
asm(nop);
asm(nop);
asm(setb portb.4);
void send(int thebyte)
//send the byte back through the USB interface
SETPORTDOUT;//set data direction to output
//when TXE is high do not write
FIFO_busy=1;
while(FIFO_busy)
asm(mov w,porta); asm(mov FIFO_busy,w); FIFO_busy &= 0x04; //read TXE
portd = thebyte;//put data on the bus
delay_usec(10);
asm(clrb porta.1);//A1 low - WR low
delay_usec(10);
asm(setb porta.1);//A1 high - WR high
portd = 0;
SETPORTDIN;
unsigned int read_usb()
rempty=1;
while(rempty)//while A3 (RXF) is high (no data received)
asm(mov w,porta); asm(mov rempty,w); rempty &= 0x08; //read RXF
SETPORTDIN;//set data direction to input
asm(clrb porta.0);//A0 low - RD# low
delay_usec(10);
data8 = portd;//read databus
asm(setb porta.0);//A0 high - RD# high
return data8;
void delay_msec(unsigned int msec)
while(msec--)
//pause for 1 millisecond
delay_usec(250);
delay_usec(250);
delay_usec(250);
delay_usec(250);
void delay_usec(unsigned int usec)
while(usec--)
xloop=3;
while(xloop--);
asm(nop);
asm(nop);
asm(nop);
asm(nop);
asm(nop);
asm(nop);
asm(nop);
asm(nop);
Is port D connected to anything on the board, or just pinned out to a header?
