Coding question... ...read write modify.
Ok,
I need to understand this...
Is this code valid, or not.
-Dan
"A saint-like quantity of patience is a help, if this is unavailable, a salty vocabulary works nearly as well." - A. S. Weaver
setb RD.2 setb RD.7
-Dan
It depends.
When running at high speed or when there is alot of capacitance on the pins the first SETB may not take affect.
Here is what happens:
During each port update the port input register is read, then modified, then written. The problem occurs because the port input register actually reads the state of the pins NOT the output register state.
Let's assume RD.2 is low.
The "SETB RD.2" sets the output latch high. But before the actual pin voltage level rises to a "1" level, the next SETB command reads the port input state (which is still a zero for RD.2). Then it modifies RD.7 and writes the WHOLE port back. So in the end the output latch for RD.2 gets set back to zero (which it what it was when the second SETB read the input state).
I hope that makes sense...
Bean.
I know what I know, don't confuse me with the facts...
www.hittconsulting.com
It makes sense. However,·I consider it a bug in the chip,·it acts differently
based on specific hardware setups, and system voltages.·The above code
works·at 5 volts but not 3.3 volts.
I think that the assembler needs to be coded to detect these·situations, and
provide a warning about needing a nop...
Can this be done?
-Dan
It is always best to avoid back-to-back port changes. You could change to "OR RD,#$84" and that would do the same thing with only one port access (but sets W to $84).
Also you may need more than 1 NOP, you may need many cycles until the pin reaches the new state.
I don't have any control over how the assembler works, so I'll have to let someone else answer that.
Bean.
As Bean suggested, placing NOP instructions for a short delay between subsequent SETB instructions helps in many cases, although the required delay depends on the external capacitive load, the clock frequency, and the supply voltage.
Even when you configure a port pin as an output, the pin state is read back via the input port circuit. This means that the level configuration is in effect, so defining the input level for such a pin as TTL (with a threshold of about 1.4V), or having it set to CMOS (threshold = Vdd/2) has an effect on the read-modify-write behavior.
Another option is using a "shadow" register, like this
mov Shadow, RD
setb Shadow.2
setb Shadow.7
mov RD, Shadow
This completely eliminates the problem, as all port pins are read and written in parallel. I must admit that the four additional clock cycles required to read and write the shadow register could also be taken for up to four NOPs between the SETB instructions that directly modify the port outputs. I normally make use of a shadow register in an ISR when different parts of code set or reset port pin states, and write the updated state to the port immediately before leaving the ISR.
Greetings from Germany,
G
could be rewritten
This inserts the necessary delay between SETBs without using any more clock cycles than the original code.
Having a warning about successive writes to a port would have flagged me, and I would have caught it.
Again, I warning in assembler would be nice.
The problem with the shadow register is that if code in multiple VP's uses a pin on a port, it gets more difficult to update the port settings. This is espically the case for multiple high speed communications VP's.
Phil,
I know about threading op codes together. I had one project where I needed to·manually thread code·for a·4+mbit/s continuous data link that needed to cycle·at·exactly 3996 clock cycles. Got real good at watching W,C, and Z [noparse];)[/noparse]
Anyway,
The problem was that I KNEW about this problem, but with a rushed schedule I didn't have time to spare, and a simple warning would have been a life saver.
Dan
