Propeller 'old-school' BBS (running on prop)
Oldbitcollector (Jeff)
Ok.. Next step!
I have a small BBS running on my propeller you can telnet to at:
propeller.petscii.com or by IP 71.55.60.10 (port 23)
TELNET 71.55.60.10
Hit [noparse][[/noparse]ESC] once you connect to activate the board.
The system was designed with PropCOMM in mind and will
work with the program prop-to-prop from this thread:
(You'll need BBS Server from the same thread)
http://forums.parallax.com/showthread.php?p=675748
There's a few commands, log in and write something on my SD card, and flash my LEDs!
I didn't realize .spin was this easy.. gheesh..
Oldbitcollector
Buttons . . . check. Dials . . . check. Switches . . . check. Little colored lights . . . check.
— Calvin, of 'Calvin and Hobbes.
TELNET 71.55.60.10
Oldbitcollector
Kudos to Oldbitcollector!
But it betrayed you : the BBS is not running on a Propeller, but on a WOPR
Nice work
Eric
More about my robotics related activities on : www.pobot.org
Best regards,
Coley
PS I left you a message on the SD Card lol
Last entry on the menu was funny too, although I thought you'd have mentioned doing something else first too [noparse]:)[/noparse]
Kudos indeed.
Baggers.
Think I'll transfer it to one of my other prop boards and leave it running on my desk.
Some prop-to-prop file transfer would be cool, I think I'll add that next.
(As you can see, I already have a bunch of games on that SD card.)
Hey Brian! Are those SpinStudio Ethernet boards going on sale soon?? <GRIN>
Anyone try the BBS with PropCOMM yet?
Oldbitcollector
The BBS is really a few pages of code glue that uses:
FullDuplexSerial
TVtext
Fsrw
comboKeyboard
Soon I'll include Harrison's 'tcp/ip' stuff..
6 months and I'm still blown away by the power in this thing!
Oldbitcollector
- Sparks
Oldbitcollector
1. It would be useful for the prop to have date/time
2. How do you know someone has disconnected? Are you checking the CD pin (Pin1 on the DE9 connector), waiting for a timeout or looking for a DISCONNECT string?
The prop currently does not store the real date/time.
You could monitor Pin1 if you attached a wire via a diode/resistor to a prop pin. Your code could then determine if someone disconnected.
The BBS Server software resets the port when someone disconnects causing the propeller to reset.
(BBS resets)
I don't have date and time in place yet, at least not on the prop.
Oldbitcollector
I'll add some more features soon!
Does not seem to like odd characters in the (w) command..
No, you didn't break it, but I'm sure the text file is interesting... <grin>
I'll brew up a pot of coffee this evening and see if I can get more stuff working on it.
I'm also working on a better version of PropCOMM (terminal) for the BBS, it will be
required for the file transfer section. Think uploading/download spin binaries. [noparse];)[/noparse]
Oldbitcollector
That is exactly what I was thinking
Brian
uController.com - home of SpinStudio
Thanks!
Oldbitcollector
Some of you even tried the [noparse][[/noparse]D]ownload link [noparse]:)[/noparse] Nope, Telnet won't support downloading.. <grin>
But at the moment, neither will PropComm2. I've managed a type of ASCII (if you can call it that)
transfer, but I'm starting to feel like Geordy Laforge fixing a transporter problem. What I wind up
with on the other side doesn't correctly resemble the original. I'm reviewing how Xmodem works
right now... Has anyone else done prop-to-prop binary transfer yet?
Oldbitcollector
