Byte variable expected
I declared a variable "ms" as
ms var Byte(1)
and when I debug the program it comes to a line
READ Seg_Map + ms, display(0)
and I get the "Byte variable expected error 11"
ms var Byte(1)
http://forums.parallax.com/showthread.php?p=597707
I just tried this code and it works with SX/B version 1.51.03 (the latest).
DEVICE SX28, OSC4MHZ, TURBO, STACKX, OPTIONX, BOR26 FREQ 4_000_000 ms VAR BYTE(1) display VAR BYTE(10) PROGRAM Start Start: READ Seg_Map + ms, display(0) END Seg_Map: DATA 0, 1, 2, 3, 4, 5, 6
Bean.
I know what I know, don't confuse me with the facts...
www.hittconsulting.com
I had declared my data table Seg_Map as a Byte(3)
commenting out this line eliminated the error.
Sometimes if the supply voltage rises slowly, the SX doesn't start properly. The BOR26 holds the SX in reset until the supply reaches 2.6 volts.
Seg_Map should be a lablel not an array ?
If you post your program I'd be happy to help you more.
Bean.
