Wire size, current carrying capability — Parallax Forums
k4shfk4shf Posts: 21
edited 2007-09-18 22:24 in Robotics
confused.gif·What size is the wire from the battery pack of the sumo?· What is the current handling capability of it?
Thanks!
Tim T.
freaked.gif·
    edited 2007-09-18 06:14
    I don't have a SUMO bot. Wish I did to be more helpful.
    You can try this link for copper wire info. Includes
    gauges, lengths, amps, resistances, AWG tables,
    conductivities, etc.
    www.radiolocman.com/shem/shem-cache.html?di=18899
    humanoido
    edited 2007-09-18 06:45
    k4shf,
    I don't have a unit right in front of me to determine the exact wire AWG, but a typical connector would be 20-22 AWG.
    There is a formula to calculate current based on wire gage...
    Circular Mils =·((92 ^ ((36-AWG)/39))*5)^2
    Maximum Current Density = ( Circular Mils / Current Density Constant·) * Dv
    To be conservative most people use·a 'Current Density Constant' value of 1Amp for every 700 Circular Mils, so for 20-22 AWG wire you are looking at a maximum current density·of about 1.5Amps to .9Amps
    There is also a derating value based on the number of strands in the wire...
    2-5 strands Dv = .8
    6-15 strands Dv = .7
    16-30 strands Dv = .5
    Beau Schwabe
    IC Layout Engineer
    edited 2007-09-18 07:59
    I guess what you are think about is power drain at a completely stalled motor.
    1.5amps may not be enough in competition.
    Instead of 20-22 AWG, try 12-14 AWG for about 15 AMPs. Then it will merely be the limits of your motor, motor control circuit, and batteries.
    Of course you don't really have to go that big. But wire cross-section is directly limiting the current capacity regardless of voltage.
    "Everything in the world is purchased by labour; and our passions are the only causes of labor." -- David·Hume (1711-76)········
    ···················· Tropically,····· G. Herzog [noparse][[/noparse]·黃鶴 ]·in Taiwan
  • k4shfk4shf Posts: 21
    Yeah....what I've got is 2650 mah NiMH cells....in the standard cell holder, that's only 4.8 volts...not good for electronics or servos.
    Adding in a cell. Cell holder has leades that are 26 awg, not easy to solder on larger wire (without metling plastic).
    Looking at upgrading servos to higher torque....increasing friction of tires....assuming that stall current of servo increases....
    Or am I all wet and without a clue?
    Tim T.
