Hydra and 10MHz Crystal
hippy
The Hydra uses a 10MHz crystal then code runs using PLL8x giving 80MHz execution speeds.
Can anyone tell me what the advantage is of doing that rather than using a 5MHz crystal and PLL16x ?
On a very insignificant level, there is a slight difference in crystal drive current. Around 300 uA for 5 MHz and 500 uA for 10 MHz.
Post Edited (deSilva) : 9/17/2007 7:52:55 PM GMT
And my Proto Boards (5) run fine.
| Proto) & pll8x))
| Proto) & 14_318_180)
Sapieha
However.... The PLLs of SOME Propellers might run with 12 MHz, perhaps some very few with 14.. ??
@ Mike : I hadn't noticed the Spin Stamp also used 10MHz, thanks. Smaller footprint; that makes a lot of sense.
