SX Proto Board and using a 4N25 as an input for the SX
Hi, Every One
I looked at the Data Sheet for the 4N25
at web page http://gamma.octopart.com/Fairchild__4N35.pdf
The problem that i have is what value do I need for the resisters in the test circuit they have on there web page
·there are no values listed·I will be using 5 volt regulated as the input to the 4N25 an the SX input
Can any one help with this
·Thanks for any help that any one can give me
·Thanks For all·the Help that You Can Give So that i can know·how to write SX Code
······································· Stefan
Post Edited (Little_Part_Man) : 9/17/2007 11:24:31 AM GMT
There's nothing like a new idea and a warm soldering iron.
Thank You for your reply
I will give this a try and see what i come up with
Will i need a resister· from the base to emitter and if so
Just enough to get a logic "0" and logic "1" this what i am thinking
Please let me know if i am right about this or not
Thank You for your help
