24LC256 will not accept 32 bit data ending in "1"
This is all very strange and I need a fresh set of eyes to look at this.· I'm trying to write 32bit words to another 24LC256 mem chip on pins 26 and 27 to log accelerometer values.· The read and write driver is asm, (my first venture into asm) and it almost works!
If I write 4 consecutive bytes and retrieve them, the data comes back in-tack if the 32 bit value was even.· it does not matter where on the memory I put the data it rejects the whole 4 bytes if the last bit is a one.·· The mem chip is sending good acks after each byte sent but then when I go look nothing was written.· If an even value is written to the same address then it goes in presumably because it certainly comes back.··· The data sheet for the memory states that the clock needs to be high for 600 nSecs and low for 1300nSecs which I was not doing so I thought the problem was solved but it is slowed down now and still the same issue.·
I'd be glad to post the asm for this if anyone is interested.··
thanks.·
thanks.·
Or, better yet, use the PASD (see that thread) by Ariba. It is exactly what you need for this kind of problems.
Then for reading, everything is shifted into the LSB of a long (8 bits) * 4
We can also give you general hints as to debug techniques (pencil-and-paper, "ViewPort", which might be of good help,...)
But it seems obvious that you have a bug in your code, and so not posting it, will hinder progress..
Post Edited (deSilva) : 9/15/2007 7:40:25 AM GMT
Remember outa[noparse][[/noparse]SDA] := 0, always. dira[noparse][[/noparse]SDA] is used to control the state of the SDA pin: dira[noparse][[/noparse]SDA] := 1 => SDA is low; dira[noparse][[/noparse]SDA] := 0 => SDA is high.
Here's a Propeller Eeprom object I'm preparing for the next Propeller Education Kit lab.· It's written in Spin and has been working pretty well so far.· It might help for comparison's sake.· Also, if you unearth any bugs in it during the comarisons, please let me know.
Thanks, Andy
P.S. Hoping to post demo code to another thread later this weekend.
Andy Lindsay
Education Department
Phil, if I follow you, your saying that after the last byte is transmitted the SDA line is left in its last state, then when the Stop is issued there is no transition for SDA if it was already a 1.
Look at line 243 snd_data, here is where I'm sending a byte out, then look at line 305 stop, I have totally left SDA flapping in the wind and I think you nailed it Phil.·· I have not tested it yet but it looks like this must be it.· GOOD DIAGNOSTICATING!· Thanks!.··
Thanks again!
Is there more to it than just releasing the bus or would you say that electrically it is a better practice to allow the pullup to create the high state?·· I would think that the master would only incur electrical current for low periods even if using outa.··
*Peter*
I beg to disagree. Even in single-master I2C systems, neither master nor slave devices should ever drive SDA high, since it's bi-directional. The whole idea is to avoid bus conflicts. Moreover, it's okay for a master to drive SCL high only when the slave devices are incapable of clock stretching. In most cases, that's a safe bet, but you do have to read the datasheets to make sure.
Although...... I guess there could be some nasty currents on the line and through devices if One was driving low and the other high, then the current would not go through any resistor and could burn either device.· This would effectively be a short.·
····"The output stages of devices connected to the bus must have an open-drain or open-collector to perform the wired-AND function."
In most single-master systems, though, SCL can be driven both high and low, since it's not bidirectional. The exception occurs when there are one or more slave devices on the bus that employ clock-stretching to slow the timing. In that case, the same rules apply as for the SDA line.
Post Edited (Phil Pilgrim (PhiPi)) : 9/16/2007 5:16:00 AM GMT
