Question regarding RX on FullDuplexSerial
I'm writing a communication routine that checks for data from both the propeller keyboard as well as a remote source.
Here's a snippet from the routine.
When the code hits e:=ser.tx it freezes, I assume waiting for something to actually come back
from the remote source. Can someone show me a way to make it behave more like the key.getkey function
so that it doesn't care if nothing is there or not and keeps on going? I'm running this in a loop, so it will
have a chance to check again in a few milseconds.
Thanks!
Oldbitcollector
Buttons . . . check. Dials . . . check. Switches . . . check. Little colored lights . . . check.
— Calvin, of 'Cavin and Hobbes.
PRI getline | i, c ,a,d,e
i := 0
repeat
c := key.getkey
e := ser.rx
text.out(e)
Thanks!
Oldbitcollector
PUB rxcheck : rxbyte '' Check if byte received (never waits) '' returns -1 if no byte received, $00..$FF if byte
PRI getline | i, c ,a,d,e i := 0 repeat c := key.key if c <> 0 'text.out(c) 'Half Duplex when this line is not remarked ser.tx(c) if c == fReturn ser.tx(10) ser.tx(13) if c == bspKey ser.tx(8) e := ser.rxtime(10) if e > 10 'text.dec(e) text.out(e)
Now, I've got a terminal program on my prop!
(Been dialing TelBBS systems with the propeller today. *very cool*)
Now to the bigger project. [noparse]:)[/noparse]
Oldbitcollector
