Broadcast - Help needed
Do you just need one pin for broadcast mode or do you need all 4?
and what do the settings have to be set to. i.e. pins, mode, broadcast, auralcog?
Thank you
Check out my robot using the propeller robot.tmcp.com.au
If you offer cheap PCB fabrication, perl programming or any other helpful services please email me at.
anthonybmyatt@yahoo.com.au
Post Edited (computer guy) : 9/16/2007 6:09:05 AM GMT
Thank you
30cm wide.
16cm tall. (Not including ping sensor on top).
Thanks for showing interest.
Am redesigning the site soon.
Know anything about broadcast mode?
Using an additional "Aural COG" is a little bit more complicated.
I have to admit I never did it
Thank you
Thank you
A group of 8 pins is used for video, 4 of them are used for baseband, 4 for broadcast. The latter four are the "modulated" former four.
You control (or suppress) their outputting to the physical pins by "tv_pins" settings.
You need at least three pins to form 8 voltage levels by an external 1:2:4 current DAC, as the propeller cannot output analogue signals by itself.
1) The aerial is just a piece of wire instead of the cable to TV for baseband, right ?
2) Does the Propeller / TV.spin support broadcast to UHF channels, > 500 MHz ?
3) Is using the 5MHz crystal on the Proto Board sufficient for PAL broadcast, or do I need a 4.33<whatever> MHz crystal ?
4) Has anyone got PAL Broadcast working ?
I've got TV.spin working with NTSC and PAL to my wired-TV ( very acceptable results for PAL even at 5MHz ), but the portable TV receiver will only accept PAL so it's a bit hard to experiment to take factors out of the equation. PAL CVBS video in works okay but not quite as nicely as on the main TV.
2) The Propeller can't generate signals beyond about 160MHz or so. That covers the lower VHF channels only.
3) The 5MHz crystal generates lousy signals for NTSC broadcast and I assume the same is true for PAL. You really want a sub-multiple of the broadcast channel frequency, maybe some magic combination of the color burst frequency and the channel frequency. In the USA, a 6MHz crystal works better because the channels are all multiples of 6 MHz. Most sets can lock on quite well to a 60 or 66 MHz carrier.
2) Yes, it was with hindsight pretty silly of me to expect 500MHz+ !
3) I may play around with various crystals and try and find a 'sweet channel' later as this really was just playing to hope to impress non-techies - "Propeller TV Station on a Chip".
The UK abandoned VHF many years ago and UHF is about to get switched off so it's hard to even find TV's with VHF tuners. TV CVBS was what I was really after and that works well enough for me ( 40x16 PAL ). Most impressed.
Thank you
'' tv_pins '' '' bits 6..4 select pin group: '' %000: pins 7..0 '' %001: pins 15..8 '' %010: pins 23..16 '' %011: pins 31..24 '' %100: pins 39..32 '' %101: pins 47..40 '' %110: pins 55..48 '' %111: pins 63..56 '' '' bits 3..0 select pin group mode: '' %0000: %0000_0111 - baseband '' %0001: %0000_0111 - broadcast '' %0010: %0000_1111 - baseband + chroma '' %0011: %0000_1111 - broadcast + aural '' %0100: %0111_0000 baseband - '' %0101: %0111_0000 broadcast - '' %0110: %1111_0000 baseband + chroma - '' %0111: %1111_0000 broadcast + aural - '' %1000: %0111_0111 broadcast baseband '' %1001: %0111_0111 baseband broadcast '' %1010: %0111_1111 broadcast baseband + chroma '' %1011: %0111_1111 baseband broadcast + aural '' %1100: %1111_0111 broadcast + aural baseband '' %1101: %1111_0111 baseband + chroma broadcast '' %1110: %1111_1111 broadcast + aural baseband + chroma '' %1111: %1111_1111 baseband + chroma broadcast + aural '' ----------------------------------------------------------- '' active pins top nibble bottom nibble
Assuming "A16...A19" means P16...P19, you should set tv_pins to %010_00xx, where xx depends on what combination of broadcast/baseband/chroma/aural you want. HTH.
Must have overlooked that table.
