Want to display 2.4ghz on a Plasma at a Convention
Hi, I am trying to create an in-booth activity for a tradeshow where a participant enters there name and some other information and they get to see it wirelessly transmitted to a printer.· My original intention was to use a USB-interfaced oscilloscope to display the data on a plasma screen, however, the relatively inexpensive version Parallax puts out only goes up to 200khz.· Does anyone know of an economical alternative that can measure the 2.4ghz wifi bands?
Thanks!
Thanks!
My experience with trade shows has taught me that things that work at home don't always perform the same in a convention hall, be it from weird lighting, RF interference, you name it. I've also found that trade show goers are less likely to participate in a booth display than you might hope. That latter observation comes from industrial shows, however. If yours is attracting a geekier crowd, that might not be the case.
Steve
Note that·your PC network card does all the work for you: it catches the signal and filter the right data.
If you insist in using hardware to·read the signal, aside form Wi-Spy there are other cheap solutions. One of them is Prisma PCMCIA wireless cards that ares sold cheap on eBay, but have the problem of being very slow at·sweeping,·even when they concentrate on·the 2.4ghz·band only.
Mid-level spectrum analyzer·do reach 2.4Ghz. Some of these have VGA output so displaying the wave is easy, although pretty boring. You·might rent one for the show.
I think·the PC itself displaying the network traffic would·be much more interesting.
