36mosfets, no space =(
Hello! its been a while hehe.....
i have to work in this project for a robotic arm that has 6 very small sensorless brushless motors rated at 26ma to do the trick i use pwm signals and a 6 mosfet bridge for the 3 signals needed but the problem is that i have very limited space for the bridges and i was thinking about using some kind of logic chip instead the mosfets to do the trick......is there any solution for this or is it just crazy? =P
cheers
"The Only Thing Im Sure Of Is That Im Never Sure Of Anything"........
cheers
Deno
Post Edited (Scarecrow) : 9/11/2007 7:02:36 AM GMT
Lunch cures all problems! have you had lunch?
You need to be careful when looking at the IC specs for Source and Sink I/O currents. Many times you might find something that can source or sink what you need, but if you use several of those pins at the same time the current will exceed the rated current limit for the IC itself.
If a standard H-Bridge is too much overkill, you might be able to compromise with an Op-Amp that can handle low voltage and "higher" currents. If you have 6 three phase motors, then I think that 5 of these IC's would work just fine with 2 Op-Amps to spare.
www.ortodoxism.ro/datasheets/texasinstruments/opa4684.pdf
This is a QUAD Op-Amp that has an output drive of 120mA..... Each motor would require 3/4 of the IC, so 5 IC's would be required.
Beau Schwabe
IC Layout Engineer
