Trouble with RCTIME to monitor a 12V SLA Battery — Parallax Forums
DavidMDavidM Posts: 640
edited 2007-09-10 03:02 in Propeller 1
HI,
I am having trouble with RCTIME to monitor a 12 VOLT SLA BATTERY ( the battery is used to power the propeller circuit and I want to display its "LEVEL" on 8 LED's. in this case I am just using the 8 LED's of the PROP DEMO Board.
Attached is my code and schematic..
I think I have the correct idea but i am not sure of some of the values/calculations for ..
1) PAUSE the start of the routine so as to CHARGE the CAPACITOR
2) ADJUST the time for the SPIN code that has executed so far.
3) Once I get some kind of value I need to "SCALE" / ADJUST" it to meet my desired output.
I am getting NO RESULTS so far and I also don't have any DEBUGGING setup, BUT I believe I need it for this kind of task.
My RCTIME routine is called "GetVoltage"
I don't even think my capacitor is charging!
'' RCTIME 12V BATTERY MONITOR TEST
CON
  _CLKMODE     =XTAL1 +PLL16X
  _XINFREQ     =5_000_000
VAR
  LONG  RcTimePinNo
  LONG  BatteryVoltage
  LONG  RcTemp
PUB Main
  RcTimePinNo  :=0
  DIRA[noparse][[/noparse]16..23]~~             ''Make leds outputs
  OUTA[noparse][[/noparse]16..23]:=%00000000    ''Turn them off
  REPEAT
    BatteryVoltage:=GetVoltage( RcTimePinNo)    '' VALUE between 130 to 100 to be returned   13V to 10V ??
    CASE  BatteryVoltage
       130..129:  OUTA[noparse][[/noparse]16..23]:=%11111111     ''13.0 Volts - Fully Charged   13V??
       128..127:  OUTA[noparse][[/noparse]16..23]:=%11111110     ''12.8 Volts
       126..125:  OUTA[noparse][[/noparse]16..23]:=%11111100     ''12.6 Volts
       124..123:  OUTA[noparse][[/noparse]16..23]:=%11111000     ''12.4 Volts
       122..121:  OUTA[noparse][[/noparse]16..23]:=%11110000     ''12.2 Volts
       120..116:  OUTA[noparse][[/noparse]16..23]:=%11100000     ''12.0 Volts
       115..101:  OUTA[noparse][[/noparse]16..23]:=%11000000     ''11.5 Volts
       100..0  :  OUTA[noparse][[/noparse]16..23]:=%10000000     ''10.0 Volts - Battery Just about Dead, 10V??
PUB GetVoltage(vRcTimePinNo) : vBatteryVoltage
    RcTemp := 0                         ''Initialise RcTemp
    OUTA[noparse][[/noparse]vRcTimePinNo] := 0             ''Set it Hi to CHARGE capacitor
    DIRA[noparse][[/noparse]vRcTimePinNo] := 1             ''Make pin an OUTPUT
    WAITCNT(CLKFREQ / 2000 + CNT)       ''PAUSE for 0.5ms
    DIRA[noparse][[/noparse]vRcTimePinNo] := 0             ''Make pin an INPUT
    RcTemp := CNT                       ''TRAP the current Time in RcTemp
    WAITPEQ( 1, vRcTimePinNo, 0 )       ''WAIT until a change occurs on pin
    RcTemp := || ( CNT-RcTemp)          ''Calculate the time LAPSED
    RcTemp := RcTemp - 1600             ''ADJUST the time for SPIN code executed
    vBatteryVoltage :=RcTemp   ''Divide by 16 and store in the Battery Voltage Variable
Dave M
    edited 2007-09-09 13:27
    Dave,
    You need to discharge the capacitor first then let the +12V charge it which by the way is what you are actually doing. The RC time constant does not change but the of course the time it takes to get to the logic inputs threshold voltage will decrease with higher voltage due to higher charge rate.
    Why isn't RcTimePinNo set to the pin mask because 0 will not achieve anything. If it is P8 for instance then the mask should be %1_0000_0000.
    *Peter*
    EDIT:
    My mistake Dave, it was late and I sometimes forget this is Spin on the prop. OUTA and DIRA do take a pin number, not a mask. Is P0 the pin you are using?
    *Peter*
    Post Edited (Peter Jakacki) : 9/9/2007 10:36:05 PM GMT
  • DavidMDavidM Posts: 640
    edited 2007-09-10 00:37
    HI pete,
    Yes PIN 0 is the pin I am using that is connected to the capacitor, Did you look at my schematic?
    It also declares is here in my code..
    PUB Main
    RcTimePinNo :=0
    So I gather I have to discharge that cap first, Is that what the PAUSE is for?
    So I have modified my code as below.
        OUTA[noparse][[/noparse]vRcTimePinNo] := 1                  ''Set it HIGH to DISCHARGE capacitor
        WAITCNT(CLKFREQ / 2000 + CNT)       ''PAUSE for 0.5ms                              ( Is this enough time for discharge?)
        OUTA[noparse][[/noparse]vRcTimePinNo] := 0                  ''Set it LOW to CHARGE capacitor ( Is this correct ?)
        WAITCNT(CLKFREQ / 2000 + CNT)       ''PAUSE for 0.5ms                                ( Is this enough time for charging?)
        WAITPEQ( 1, vRcTimePinNo, 0 )          ''WAIT until a change occurs on pin                          ( is this syntax correct?)
    Dave M
    edited 2007-09-10 00:44
    One change I need..
    should be..
    WAITPEQ( 1, |<vRcTimePinNo, 0 )
    the |< operator is a bitwise decode which will take any pin NUMBER 0-32 and convert it to the correct bit pattern
    ie. %00000000_00000000_00000000_00000001
    Is this correct?
    Dave M
    edited 2007-09-10 01:50
    See, I am confused. I remember now why I said you needed a bit mask and that was the reason. So that is correct. I assume you have already tried it then?
    *Peter*
        OUTA[noparse][[/noparse]vRcTimePinNo] := 1                  ''Set it HIGH to DISCHARGE capacitor  !!! WRONG, this needs to discharge first so OUTA[noparse][[/noparse]pin]  := 0
        WAITCNT(CLKFREQ / 2000 + CNT)       ''PAUSE for 0.5ms                              ( Is this enough time for discharge?) !!! you could make this 10us (470x
        OUTA[noparse][[/noparse]vRcTimePinNo] := 0                  ''Set it LOW to CHARGE capacitor ( Is this correct ?) !!! WRONG - don't do this, you want the input to charge the cap.
        WAITCNT(CLKFREQ / 2000 + CNT)       ''PAUSE for 0.5ms                                ( Is this enough time for charging?) !!! SKIP
        RcTemp := RcTemp - 1600                 ''ADJUST the time for SPIN code executed           !!! this is simply to zero offset the count, might need trimming
        vBatteryVoltage :=RcTemp                ''Divide by 16 and store in the Battery Voltage Variable !!! the reason you want to divide is you have too much resolution and noise
    Although the capacitor charging is non-linear you will find that the initial charge curve is fairly linear so you can read the value and perform a simply calculation to get the volts.
    *Peter*
    250 x 150 - 2K
