Propeller Layout View Contest - CLOSED - Page 5 — Parallax Forums
1235»
  • Jeff McClureJeff McClure Posts: 75
    edited 2007-09-05 15:56
    As per the Doc we were to use it was called Main RAM, and Main Rom just as I put first
  • edited 2007-09-05 16:13
    Aha! It appears we have a tie.
    Congratulations to Kaio AND Jeff McClure.
    You will both get a prize.
    Cheers, PPF
    edited 2007-09-05 16:18
    Jeff,
    Congratulations!!
    What happened, is that I was going by the BLOCK diagram, which denotes HUB RAM and HUB ROM, but you are completely correct!
    'Main ROM' and 'Main RAM' are also completely valid.
    Beau Schwabe
    IC Layout Engineer
  • Fred HawkinsFred Hawkins Posts: 997
    edited 2007-09-05 16:20
    Beau Schwabe (Parallax) said...
    ·I'm gonna have to re-LVS after that
    LVS means? (Google didn't help)
    edited 2007-09-05 16:24
    LVS - Layout verses Schematic ....· Since you changed the Layout on me, it's not going to match the schematic anymore. smilewinkgrin.gif
    Beau Schwabe
    IC Layout Engineer
    edited 2007-09-05 16:54
    Sounds like a dance that I haven't had to learn. Two step or tango?
