Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
Propeller Layout View Contest - CLOSED - Page 5 — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
Propeller 1
1
2
3
4
5
Jeff McClure
75
2007-09-05 15:56
edited 2007-09-05 15:56
As per the Doc we were to use it was called Main RAM, and Main Rom just as I put first
Parallax Prize Fairy
45
2007-09-05 16:13
edited 2007-09-05 16:13
Aha! It appears we have a tie.
Congratulations to Kaio AND Jeff McClure.
You will both get a prize.
Cheers, PPF
Beau Schwabe
6,572
2007-09-05 16:18
edited 2007-09-05 16:18
Jeff,
Congratulations!!
What happened, is that I was going by the BLOCK diagram, which denotes HUB RAM and HUB ROM, but you are completely correct!
'Main ROM' and 'Main RAM' are also completely valid.
Beau Schwabe
IC Layout Engineer
Fred Hawkins
997
2007-09-05 16:20
edited 2007-09-05 16:20
Beau Schwabe (Parallax) said...
I'm gonna have to re-LVS after that
LVS means? (Google didn't help)
Beau Schwabe
6,572
2007-09-05 16:24
edited 2007-09-05 16:24
LVS - Layout verses Schematic ....
Since you changed the Layout on me, it's not going to match the schematic anymore.
Beau Schwabe
IC Layout Engineer
Fred Hawkins
997
2007-09-05 16:54
edited 2007-09-05 16:54
Sounds like a dance that I haven't had to learn. Two step or tango?
1
2
3
4
5
Sign In
Register
to comment.
Cheers, PPF
Congratulations!!
Beau Schwabe
IC Layout Engineer
Beau Schwabe
IC Layout Engineer
