Propeller Layout View Contest - CLOSED - Page 3 — Parallax Forums
135
  • Jeff McClureJeff McClure Posts: 75
    edited 2007-09-05 01:05
    A Character set, log table, antilog table,sinetable,bootloader
    B Hub
    c 1/2 of I/O
  • Max WoodenMax Wooden Posts: 112
    edited 2007-09-05 01:07
    A. RAM & ROM
    B. PLL
    C. HUB Bus Sequencer
    Max Wooden
  • codemonkeycodemonkey Posts: 38
    edited 2007-09-05 01:39
    A. Hub ram (L) and portion of cog(s) ram (R)
    B. chunk of [noparse][[/noparse]cog processors - data bus - hub ram]
    C. output for pins 0-15
  • walice_drelwalice_drel Posts: 81
    edited 2007-09-05 02:01
    A.) Hub RAM
    B.) Cog
    C.) I/O Registers
    http://www.myspace.com/droidworks
  • James NewmanJames Newman Posts: 133
    edited 2007-09-05 03:30
    A) A cogs processor and ram.
    B) I/O Pins
    C) The propeller
    or maybe...
    A) Global ram (Hub ram?)
    B) I/O Pins
    C) Entire Chip (Propeller)
    edited 2007-09-05 03:43
    lol, last guess
    A) Cogs (2) and part of the Hub stuff
    B) I/O Pins
    C) Entire Propeller
  • Beau SchwabeBeau Schwabe Posts: 6,571
    edited 2007-09-05 05:19
    Here is a clue:
    Of the three images posted...
    - There are no I/O views
    - There are no RAM's·or ROM's together in the same view
    Beau Schwabe
    IC Layout Engineer
  • UnsoundcodeUnsoundcode Posts: 1,532
    edited 2007-09-05 05:52
    The clues narrow it down to a 1 in a million chance to hard to resist tongue.gif
    A. Cogs
    B. Bus Sequencer/Ram
    C. Rom
  • Harrison.Harrison. Posts: 484
    edited 2007-09-05 06:20
    A - Address Bus (left) | Hub RAM (right)
    B - Cog Enable Power Lines + Hub Logic
    C - Video Generator Color MUX
    Post Edited (Harrison.) : 9/5/2007 6:29:47 AM GMT
    edited 2007-09-05 06:25
    A - Hub Memory Address/Data Bus (left) | Hub ROM (right)
    edited 2007-09-05 06:27
    A ROM - Character set, log table, antilog table,sinetable,bootloader
    B Hub Bus Sequencer
    C Clock Selector (Mux)
    edited 2007-09-05 06:28
    B Hub Bus Sequencer
    C Video Gen Color Mux
    edited 2007-09-05 06:30
    B - Hub Bus Sequencer + Hub Logic
    edited 2007-09-05 06:32
    A Hub Ram
    B Hub Bus Sequencer
    edited 2007-09-05 06:33
    (reposted just in case the accidental edit above looks fishy...)
    edited 2007-09-05 06:38
    A - COG RAM Bus (left) | COG RAM (right)
    edited 2007-09-05 06:46
    B Hub Bus Sequencer
    C Hub Locks
    edited 2007-09-05 06:58
    B Hub Bus Sequencer, lock bits,bus +cog clock
    C Video Generator
    edited 2007-09-05 07:00
    A - Hub ROM
    B - Hub (Cog Enables, Clock, Lock bits)
    C - Video Generator
    edited 2007-09-05 07:11
    A Hub Rom Character set, log table, antilog table,sinetable,bootloader
    B Cog Special Purpose Ram on lower Left
    C Video Generator Color Mux
    edited 2007-09-05 07:20
    B Cog the Special Purpose Ram is on lower Left
    C Clock Selector
    edited 2007-09-05 07:23
    A - Hub ROM
    B - Hub (Cog Enables, Registers)
  • MarkSMarkS Posts: 342
    edited 2007-09-05 07:24
    A is ROM/RAM
    B is the Hub
    and C is one Cog
    edited 2007-09-05 07:44
    A Hub Rom (Character Set Left, log and antilog table,Sinetable,bootloader right)
    B Cog (Upper I/O logic, Ram, 8-bit pixel clock,Registers
    C Clock Register
    edited 2007-09-05 07:54
    I may be wrong but I dont think the Propeller book gives enough info to narrow down the fairly simple circuit in C (Simple compared to the others and what is in book)
  • parskoparsko Posts: 501
    edited 2007-09-05 08:38
    A - The thing that makes it go "Vroom"
    B - The thing that makes it go "chug-a-lug"
    C - The thing that makes it go "hmmm"
    Otherwise, I have no idea, I just design the tools that make these things...
    -Parsko
  • kb2hapkb2hap Posts: 218
    edited 2007-09-05 12:28
    a-ram
    b-hub bus sequencer
    c-rom
    DTQ
    edited 2007-09-05 13:01
    A 1K x32 rom
    B Cog logic
    C Band gap ref
    edited 2007-09-05 13:11
    I need help . . .. ......And the answer to this Question
