Propeller Layout View Contest - CLOSED - Page 2 — Parallax Forums
245
  • Bryan K.Bryan K. Posts: 47
    edited 2007-09-04 21:40
    A. is the memory, both main RAM and ROM along with the HUB (RAM, ROM, sequencer, configuration registers, etc.)
    B. are the I/O registers.
    C. are the cogs, all eight of them.
    Post Edited (Bryan K.) : 9/4/2007 10:50:00 PM GMT
  • Jeff McClureJeff McClure Posts: 75
    edited 2007-09-04 21:41
    Try this
    A ram
    B Hub
    C Clock selector
  • boeboyboeboy Posts: 301
    edited 2007-09-04 22:13
    Is any one right yet?
    My computer, http://forums.parallax.com/showthread.php?p=630466
    edited 2007-09-04 22:17
    A is the ROM and ram. B is the hub. C is the cogs and hub.
    A is the ROM. B is the configuration register. C is the cogs and hub.
    edited 2007-09-04 22:20
    A is the ROM and/or ram. B is the configuration register. C is the cogs and/or hub.
    edited 2007-09-04 22:23
    boeboy.
    No answers to the impossible question... It's all just for fun anyway right?
    Suppose someone answers HUB for one of the images... Is it HUB ROM, HUB RAM, HUB Configuration Register, HUB Lock Bits, HUB Cog Enables, or HUB Bus Sequencer?
    Beau Schwabe
    IC Layout Engineer
  • Twisted PairTwisted Pair Posts: 177
    edited 2007-09-04 22:24
    A = Cogs B = I/O's C = Hub ROM
    Post Edited (Twisted Pair) : 9/4/2007 10:30:37 PM GMT
    edited 2007-09-04 22:30
    A is the hub·ROM and/or ram. B is the configuration register. C is the hub Cog Enables.
    edited 2007-09-04 22:31
    A = Hub Rom B = I/O's C = Cogs
  • kb2hapkb2hap Posts: 218
    edited 2007-09-04 22:38
    a:Ram B: HUB (Bus Sequencer) C: cogs
    DTQ
  • TomCTomC Posts: 7
    edited 2007-09-04 22:42
    A=ROM and RAM
    B=HUB
    C=Registers
    Tom Clark
    edited 2007-09-04 22:44
    A Character set, log table, antilog table,sinetable,bootloader
    B Cog
    C I/O logic
  • SethSeth Posts: 61
    edited 2007-09-04 22:50
    RAM and ROM -A
    cog and/or hub -B
    I/O -C
  • Jon KeinathJon Keinath Posts: 146
    A,B,C - Transistors, All three have to have the transistors in them... don't they?
    -Jon
    www.jonkeinath.com
  • Sparks-R-FunSparks-R-Fun Posts: 388
    edited 2007-09-04 22:59
    Just for fun...
    I am guessing:
    A - Shared Resources
    B - Locks
    C - I/O
    - Sparks
    edited 2007-09-04 23:01
    A - is a semiconductor.
    B - is a semiconductor.
    C - is a semiconductor.
    Right?
  • Fred HawkinsFred Hawkins Posts: 997
    edited 2007-09-04 23:05
    a. fragments of two cogs and their ram
    b. hub support areas (clocks), hub data bus, cogs above
    c. opcode parsing and prefetch on right, opcode deciphering left.
  • ciw1973ciw1973 Posts: 64
    edited 2007-09-04 23:08
    I'm going for:
    A) ROM & RAM
    B) IO
    C) COGS & HUB
    edited 2007-09-04 23:19
    try again
    A Memory
    B Looks like heavy leads power managment maybe Brown out Circuit
    C I/O logic
    edited 2007-09-04 23:24
    A = I/0's B = Hub Ram/Rom Config Control C = Cogs
    edited 2007-09-04 23:30
    A = Hub Ram/Rom Config Control B = Cogs C = I/O's
  • MicknightMicknight Posts: 10
    edited 2007-09-04 23:38
    A = Global ROM/RAM
    B = HUB
    C= I/O
    edited 2007-09-04 23:40
    A Memory
    B hub Config reg
    C I/O
    edited 2007-09-04 23:48
    A = Cogs B = Hub Ram C = I/O's
    edited 2007-09-04 23:52
    A = Cogs B = Hub Rom C = I/O' s
    edited 2007-09-04 23:54
    A = I/O's B = Hub Ram/Rom C = Cogs
  • LawsonLawson Posts: 870
    edited 2007-09-04 23:59
    ok, my stab in the dark
    A - the edge of the Hub ROM. (specifically decoders on the right, and the ROM grid on the left?)
    B - Lock bits in the HUB? (it's evil to show such small chunks of a chip this big...)
    C - I/O pin drivers? (the circuit's building up power for *something* off to the right)
    Marty
    Lunch cures all problems! have you had lunch?
    edited 2007-09-05 00:08
    B Hub Config Control
    C Clock selector
    edited 2007-09-05 00:45
    any hints for us
