Propeller to LCD
Hi Guys,
I am linking a prop to a Milford Instruments LCD Serial backplate (which is very similar to the Scott Edwards ILM unit) and got the old problem of 3.3v signal from Prop to a 5v signal requirement on the Serial board. Has anyone done it and how..·The PIC isn't tolerent of 3.3V signals so I need to boost the signal, what's the best/cheapest way of doing it without inverting the signal.
Jon
Jon
Have you tried it? I mean; will the LCD accept comm's at 3.3V (might be high enough to trigger the logic...)?
Cheers,
Simon
www.norfolkhelicopterclub.co.uk
You'll always have as many take-offs as landings, the trick is to be sure you can take-off again ;-)
BTW: I type as I'm thinking, so please don't take any offense at my writing style
David
