Sound on BS2
I am using the BS2 and I wanted to know how to interface with the·ISD4003 chip from Winbond Electronics. I have wanted to make a sound file play and·this is my chance.
Josh
Josh
http://forums.parallax.com/showthread.php?p=659734
Some have done it with the ISD4004. I used an ISD25120 older 2 minute voice chip too.
Josh
Was this for a new design where you needed large quantities or just 1-2 units? If the secondary is true then any ISD chip can be used for your design.
Josh
You haven't clearly indicated what it is that you're trying to do, but there are two native PBASIC commands which may be of some help if you're looking for simple sounds. One is the FREQOUT command, and the other is the SOUND command. Both are well explained in the PBASIC Reference Manual, and the PBASIC Help File as well.
Bruce Bates
- AP-8 from EFX-TEK
- The uMP3 from Rogue Robotics
- the Cowlacious Scary Terry chipcorder kit
- The Make Magazine Daisy mp3 player
- The FTDI Vmusic module.
I spent a lot of time playing with the uMP3 unit and made some BSII/uMP3 demos available for download here.Hope this helps.
Vern
