Turning on and off RTCC interrupt in a subroutine problems??????
Hi guys,
I have got an issue where the RTCC interrupt keeps firing in the middle of my subroutine. I have put in code to turn the interrupt off in the subroutine before I do anything and then turn it back on after I have finished. Can I actually do this? As it doesn't seem to be working. If I turn the interrupt off at the beginning of the code, it runs perfectly.
SX48 Datasheet doesn't offer much information on this.
Any tips or suggestions, the interrupt has to stay as it is used as a base timer for timeouts in other subroutines.
Cheers
Stolzie
Cheers
Stolzie
ReadEE
; Read Word at EEAddr to EEDatL,EEDatH
mov w, #%01001000; #(RTCC_PS_OFF) ; setup option register
mov !option, w
clrb SPI_CS
call @E2Delay300nS
clrb SPI_CLK
setb SPI_CS
_bank SPI_BANK
mov spim_out_dat,#$01 ; send start bit
call @spia
;rl,rl eeadr and then clear carry rr clear carry rr
;this will set bit 6,7 to known state of $00XXXXX
; _bank EEPROM_BANK
; rl EEAddr
; rl EEAddr
; clc
; rr EEAddr
; clc
; rr EEAddr
; mov w,EEAddr
; xor w,#$80
_bank SPI_BANK
mov spim_out_dat,#$80;w ; move $00 Control byte for EWEN
call @spia
mov spim_out_dat,#$00 ; move EEDATH
call @spia
mov globtemp1,spim_in_dat
mov spim_out_dat,#$00 ; move EEDATL
call @spia
mov globtemp2,spim_in_dat
clrb SPI_CS
setb SPI_CS
_bank EEPROM_BANK
mov EEDatH,globTemp1
mov EEDatL,globTemp2
mov w, #(RTCC_PS_OFF) ; setup option register
mov !option, w
retp
depending on how often the interrupt is fired, and how many clock cycles are required to execute the instructions in the ISR, the interrupt "steals" away clock cycles from the main program (or any subroutine called from there). IOW, it slows down the execution speed of the main code. As long as the main code is not time-critical, this is not a problem. In your case, the code handles communications via the SPI bus which is not really a time-critical operation, as the code generates the bus clock. Therefore, I wonder why cour code does not work correctly when you allow for interrupts, as it normally should.
I made a similar experience in the past, and I found out that the ISR code - by mistake - did modify register contents that were supposed to be left un-touched. This can easily happen when you forget to select the correct bank within the ISR before accessing registers. So, in this case, the reason for the problem was not the interrupt per se, but bad code inside the ISR. When another bank is selected within the ISR, there is no need to restore the original bank because the FSR is automatically saved on entry, and restored on exit from the interrupt.
BTW: The SX48 also saves the contents of the MODE register when the ISR is entered, and restores it on return from the interrupt, where the "smaller" SXes don't have this feature. I just mention this here to make other lurkers aware of that fact when writing ISR code for the SX20/28.
Greetings from Germany,
G
It is strange that the code does work without the interrupt and not when it is on.
The EEPROM I am trying to talk to is a 93LC46B
; *********** ; *** ISR *** ; *********** ORG 0 ; Page0 ISR Timer ; implement various SW timers ; lowest-common-denominator timer _bank TIMER_BANK incsz baseTimer ; inc at 5us per tick with 50MHz clk jmp :timerEnd mov w,#56 mov baseTimer,w ;base timer rolls over at 1khz :LedTimer incsz LEDTimerLSB jmp :arpTimer _bank FLAG3_BANK setb flags3.TURN_LED_OFF nop :arpTimer ; ARP-timer (used for ARP response timeouts) incsz arpTimerLSB jmp :Mode2Timer inc arpTimerMSB ; inc at 0.3355 seconds :Mode2Timer _bank FLAG3_BANK sb flags3.MODE2_ENABLE jmp :dhcpTimer _bank MTWO_BANK decsz MTwoTimerL jmp :dhcpTimer decsz MTwoTimerH jmp :dhcpTimer _bank FLAG3_BANK setb flags3.MODE2_SCAN _bank MTWO_BANK mov w,MTwoScanL _bank TIMER_BANK mov MTwoTimerL,w _bank MTWO_BANK mov w,++MTwoScanH _bank TIMER_BANK mov MTwoTimerH,w :dhcpTimer _bank DHCP_BANK ; DHCP-timer (used for IP lease renewals) decsz dhcpBaseTimer0 jmp :timerEnd decsz dhcpBaseTimer1 jmp :timerEnd mov w,#4 mov dhcpBaseTimer1,w mov w,#232 mov dhcpBaseTimer0,w incsz dhcpTimer0 ; inc at 1s per tick jmp :timerEnd incsz dhcpTimer1 ; inc at 256s per tick jmp :timerEnd incsz dhcpTimer2 ; inc at 65536s per tick jmp :timerEnd inc dhcpTimer3 ; inc at 16777216s per tick :timerEnd mov w,#-250 ISRExit retiw
in the ISR code you have posted, following the ":LedTimer" label, you do a "_bank FLAG3_BANK", set the "TURN_LED_OFF" flag, and after the "nop", you continue with "incsz arpTimerLSB", and eventually you also do an "inc arpTimerMSB".
Are those two timer registers really located in the "FLAGS3_BANK" (the active bank at that time)? If not, you would mess up some other registers here. So you better replace the "nop" with a "_bank TIMER_BANK".
G
Cheers
Stolzie
It's not clear to me why you need to turn off interrupts. You say that interrupts fire during the processing of your main routine. So what? Billions of CPUs around the world have interrupts fire off all the time. The whole point of interrupts is that they fire off, get handled, and then return control to the main loop - all without affecting the main loop.
If you've got timing sensitive issues in your main loop, then perhaps you need to think about your software architecture and move the timing critical code to the interrupt itself. One of the great things about interrupts is that they handle timing critical stuff all the time.
If you have code that just sits in a loop until a count reaches a certain value before moving on, then you've got software that blocks and grinds to a halt all the time. This type of code is hard to maintain over time as you are constantly trying to figure out how to keep things moving and stopping simultaneously.
Thank,
PeterM
Thanks for the reply. I have definitely got some weird stuff happening with my board/code.
I will leave the interrupts on regardless as they are needed for other pieces of code, but it seems strange that if I turn the interrupts off the same piece of code works fine and when I turn the interrupt on it doesn't!
And I am at a loss to why it is doing this weird stuff. oh well some more debugging is required!
Cheers
Stolzie
I have discovered that my write code with interrupts on is functioning correctly but the read is not. It is constantly spitting back $FF, if the interrupts are disabled it will read the correct value every single time.
Cheers
Stolzie
as you had only posted part of your program, it is pretty hard to check the code for potential errors. It would be helpful to see the complete code, or at least the variable declarations.
I don't think that an active interrupt per-se causes the problem you have - there must be something inside the ISR code that messes up something outside the ISR. BTW: did you fix the missing _bank instruction in the ISR?
G
I fixed up the missing bank routine, and it still had the same problem. I have since tried a few things and have commented out the bank instruction that I added and the instruction below it.
;_bank FLAG3_BANK
;setb flags3.TURN_LED_OFF
And I am now able to read the eeprom values! Obvioulsy it may have something to do with the ISR and possibly the RETIW at the end of the interrupt.
Will post up the defines tomorrow, but at least it is starting to come together.
Cheers
Stolzie
ISR extract
; *** ISR *** ; *********** ORG 0 ; Page0 ISR Timer ; implement various SW timers ; lowest-common-denominator timer _bank TIMER_BANK incsz baseTimer ; inc at 5us per tick with 50MHz clk jmp :timerEnd mov w,#56 mov baseTimer,w ;base timer rolls over at 1khz :LedTimer incsz LEDTimerLSB jmp :arpTimer ;*************************** ;_bank FLAG3_BANK ;setb flags3.TURN_LED_OFF ;*************************** _bank TIMER_BANK
; **************************** ; *** BLANK EEPROM DEFINES *** ; **************************** MY_ETH_ADDR0 = $0 ; Boards Basic MAC address when EEPROM blank MY_ETH_ADDR1 = $11 ; " MY_ETH_ADDR2 = $BA ; " MY_ETH_ADDR3 = $0 ; " MY_ETH_ADDR4 = $0 ; " MY_ETH_ADDR5 = $1 ; " ; INCLUDE "SX52.inc" ; SX52.inc ;********************************************************************************* ; SX48BD/52BD Mode addresses ; *On SX48BD/52BD, most registers addressed via mode are read and write, with the ; exception of CMP and WKPND which do an exchange with W. ;********************************************************************************* ; Timer (read) addresses TCPL_R = $00 ; Read Timer Capture register low byte TCPH_R = $01 ; Read Timer Capture register high byte TR2CML_R = $02 ; Read Timer R2 low byte TR2CMH_R = $03 ; Read Timer R2 high byte TR1CML_R = $04 ; Read Timer R1 low byte TR1CMH_R = $05 ; Read Timer R1 high byte TCNTB_R = $06 ; Read Timer control register B TCNTA_R = $07 ; Read Timer control register A ; Exchange addresses CMPW = $08 ; Exchange Comparator enable/status register with W WKPND = $09 ; Exchange MIWU/RB Interrupts pending with W ; Port setup (read) addresses WKED_R = $0A ; Read MIWU/RB Interrupt edge setup, 0 = falling, 1 = rising WKEN_R = $0B ; Read MIWU/RB Interrupt edge setup, 0 = enabled, 1 = disabled ST_R = $0C ; Read Port Schmitt Trigger setup, 0 = enabled, 1 = disabled LVL_R = $0D ; Read Port Level setup, 0 = CMOS, 1 = TTL PLP_R = $0E ; Read Port Pull-up setup, 0 = enabled, 1 = disabled DIR_R = $0F ; Read Port Direction ; Timer (write) addresses TR2CML_W = $12 ; Write Timer R2 low byte TR2CMH_W = $13 ; Write Timer R2 high byte TR1CML_W = $14 ; Write Timer R1 low byte TR1CMH_W = $15 ; Write Timer R1 high byte TCNTB_W = $16 ; Write Timer control register B TCNTA_W = $17 ; Write Timer control register A ; Port setup (write) addresses WKED_W = $1A ; Write MIWU/RB Interrupt edge setup, 0 = falling, 1 = rising WKEN_W = $1B ; Write MIWU/RB Interrupt edge setup, 0 = enabled, 1 = disabled ST_W = $1C ; Write Port Schmitt Trigger setup, 0 = enabled, 1 = disabled LVL_W = $1D ; Write Port Level setup, 0 = CMOS, 1 = TTL PLP_W = $1E ; Write Port Pull-up setup, 0 = enabled, 1 = disabled DIR_W = $1F ; Write Port Direction ;********************************************************************************* ; Setup and enable RTCC interrupt, WREG register, RTCC/WDT prescaler ;********************************************************************************* RTCC_ON = %10000000 ; Enables RTCC at address $01 (RTW hi) ; WREG at address $01 (RTW lo) by default RTCC_ID = %01000000 ; Disables RTCC edge interrupt (RTE_IE hi) ; RTCC edge interrupt (RTE_IE lo) enabled by default RTCC_INC_EXT = %00100000 ; Sets RTCC increment on RTCC pin transition (RTS hi) ; RTCC increment on internal instruction (RTS lo) is defalut RTCC_FE = %00010000 ; Sets RTCC to increment on falling edge (RTE_ES hi) ; RTCC to increment on rising edge (RTE_ES lo) is default RTCC_PS_OFF = %00001000 ; Assigns prescaler to Watchdog (PSA hi) PS_000 = %00000000 ; RTCC = 1:2, WDT = 1:1 PS_001 = %00000001 ; RTCC = 1:4, WDT = 1:2 PS_010 = %00000010 ; RTCC = 1:8, WDT = 1:4 PS_011 = %00000011 ; RTCC = 1:16, WDT = 1:8 PS_100 = %00000100 ; RTCC = 1:32, WDT = 1:16 PS_101 = %00000101 ; RTCC = 1:64, WDT = 1:32 PS_110 = %00000110 ; RTCC = 1:128, WDT = 1:64 PS_111 = %00000111 ; RTCC = 1:256, WDT = 1:128 ; ************** ; *** DEVICE *** ; ************** RESET Main ID 'EIO24_1' ; ***************** ; *** VARIABLES *** ; ***************** ; *** Global *** GLOBAL_ORG = $0A flags EQU GLOBAL_ORG+0 ; various flags used by TCP/IP stack flags2 EQU GLOBAL_ORG+1 ; various flags used by TCP/IP stack fsrTemp EQU GLOBAL_ORG+2 ; various flags used by TCP/IP stack ;use to be flags3 now fsrtemp globTemp1 EQU GLOBAL_ORG+3 ; not preserved across any function globTemp2 EQU GLOBAL_ORG+4 ; not preserved across any function globTemp3 EQU GLOBAL_ORG+5 ; preserved across some functions ; *** Bank 0 *** ; (Don't use this bank - Difficulties with addressing Data) ORG $00 ; *** Bank 1 *** ORG $10 NIC_BANK = $ nicIOAddr DS 1 ; points to currently addressed register on NIC nicNextPktPtr DS 1 ; points to next packet in NIC's rx queue nicCurrPktPtr DS 1 ; points to current packet in NIC's rx queue nicRemoteEth0 DS 1 ; ethernet addr used for outgoing packet, overwritten by incoming packet nicRemoteEth1 DS 1 ; " nicRemoteEth2 DS 1 ; " nicRemoteEth3 DS 1 ; " nicRemoteEth4 DS 1 ; " nicRemoteEth5 DS 1 ; " nicCopySrcMSB DS 1 ; used by NICBufferCopy() nicCopySrcLSB DS 1 ; " nicCopyDestMSB DS 1 ; " nicCopyDestLSB DS 1 ; " nicCopyLenMSB DS 1 ; " nicCopyLenLSB DS 1 ; " nicCopyTemp DS 1 ; " ; *** Bank 2 *** ORG $20 MAC_BANK = $ TIMER_BANK = $ ; make sure TIMER_BANK[noparse][[/noparse]7] = NIC_BANK[noparse][[/noparse]7] baseTimer DS 1 ; lowest/common cog in timer chain arpTimerMSB DS 1 ; ARP-timer count arpTimerLSB DS 1 ; " LEDTimerLSB DS 1 ; LED-timer count MTwoTimerL DS 1 ; MODE2-timer count LSB MTwoTimerH DS 1 ; MODE2-timer count MSB ;macMyEth0 DS 1 ; My ethernet addr used for outgoing packet macMyEth1 DS 1 ; " macMyEth2 DS 1 ; " macMyEth3 DS 1 ; " macMyEth4 DS 1 ; " macMyEth5 DS 1 ; " ; *** Bank 3 *** ORG $30 IP_BANK = $ ; make sure IP_BANK[noparse][[/noparse]7] = NIC_BANK[noparse][[/noparse]7] remoteIP3 DS 1 ; IP addr used for outgoing packet, overwritten by incoming packet remoteIP2 DS 1 ; " remoteIP1 DS 1 ; " remoteIP0 DS 1 ; " myIP3 DS 1 ; filter value for incoming IP packets, also used in outgoing packet myIP2 DS 1 ; " myIP1 DS 1 ; " myIP0 DS 1 ; " ipCheckSumMSB DS 1 ; IP <header_checksum> ipCheckSumLSB DS 1 ; " ipLengthMSB DS 1 ; IP <length> ipLengthLSB DS 1 ; " ipProtocol DS 1 ; IP <protocol> ipIdentMSB DS 1 ; IP <identifier>, incremented each outgoing packet ipIdentLSB DS 1 ; " counter1 DS 1 ; general purpose counter variable ; *** Bank 4 *** ORG $40 ARP_BANK = $ ; make sure ARP_BANK[noparse][[/noparse]7] = NIC_BANK[noparse][[/noparse]7] host1IP3 DS 1 ; remote host1 IP address host1IP2 DS 1 ; " host1IP1 DS 1 ; " host1IP0 DS 1 ; " host1Eth0 DS 1 ; remote host1 Ethernet address host1Eth1 DS 1 ; " host1Eth2 DS 1 ; " host1Eth3 DS 1 ; " host1Eth4 DS 1 ; " host1Eth5 DS 1 ; " stPktTxBufStart DS 1 ; start address of stalled packet in NIC tx buffer ; *** Bank 5 *** ORG $50 DHCP_BANK = $ dhcpServerId3 DS 1 ; DHCP <server_identifier> = IP addr of DHCP server dhcpServerId2 DS 1 ; " dhcpServerId1 DS 1 ; " dhcpServerId0 DS 1 ; " dhcpIPLeaseTm3 DS 1 ; IP lease renewal time set by the DHCP server or 1 minute if no renewal time set dhcpIPLeaseTm2 DS 1 ; " dhcpIPLeaseTm1 DS 1 ; " dhcpIPLeaseTm0 DS 1 ; " dhcpBaseTimer1 DS 1 ; DHCP base timer for renewals dhcpBaseTimer0 DS 1 ; " dhcpTimer3 DS 1 ; DHCP timer for renewals dhcpTimer2 DS 1 ; " dhcpTimer1 DS 1 ; " dhcpTimer0 DS 1 ; " dhcpFlags DS 1 ; flags ; dhcpFlags DHCP_CONFIG = 0 ; *** Bank 6 *** ORG $60 UDP_BANK = $ udpRxSrcPortMSB DS 1 udpRxSrcPortLSB DS 1 udpRxDestPortMSB DS 1 ; filter value for incoming UDP packets udpRxDestPortLSB DS 1 ; " udpRxDataLenMSB DS 1 ; length of <data> field of incoming UDP packet udpRxDataLenLSB DS 1 ; " udpTxSrcPortMSB DS 1 udpTxSrcPortLSB DS 1 udpTxDestPortMSB DS 1 udpTxDestPortLSB DS 1 udpTxDataLenMSB DS 1 ; length of <data> field of outgoing UDP packet udpTxDataLenLSB DS 1 ; " UDPAPPSTATE DS 1 ; Flags Register for UDP recieved Command Packet FIFORP DS 1 ; Read Pointer for Output Data FIFO FIFOWP DS 1 ; Write Pointer for Output Data FIFO FIFOSZ DS 1 ; Current Data Size in Output Data FIFO ; UDPAPPSTATE CLOCKME = UDPAPPSTATE.0 WRITEA = UDPAPPSTATE.1 WRITEB = UDPAPPSTATE.2 WRITEC = UDPAPPSTATE.3 WSPEC = UDPAPPSTATE.4 ECHOB = UDPAPPSTATE.5 DiscoverNow = UDPAPPSTATE.6 RequestNow = UDPAPPSTATE.7 ; *** Bank 7 *** ORG $70 EEPROM_BANK = $ EEAddr DS 1 ; Address 0-63 EEDatH DS 1 ; High Byte Data EEDatL DS 1 ; Low Byte Data TARGET_BANK = $ ;Target for Mode 2 Data TargetEth0 DS 1 ; Target MAC Address for Mode 2 Data TargetEth1 DS 1 ; /\ TargetEth2 DS 1 ; /\ TargetEth3 DS 1 ; /\ TargetEth4 DS 1 ; /\ TargetEth5 DS 1 ; /\ TargetIP0 DS 1 ; Target IP Address for Mode 2 Data TargetIP1 DS 1 ; /\ TargetIP2 DS 1 ; /\ TargetIP3 DS 1 ; /\ TargetPort0 DS 1 ; Target Port Number for Mode 2 Data TargetPort1 DS 1 ; /\ ; *** Bank 8 *** ORG $80 MTWO_BANK = $ MTwoMaskA DS 1 ; Mode2 Mask bits for port A MTwoMaskB DS 1 ; Mode2 Mask bits for port B MTwoMaskC DS 1 ; Mode2 Mask bits for port C MTwoScanL DS 1 ; Mode2 Scan Rate LSB MTwoScanH DS 1 ; Mode2 Scan Rate MSB MTwoFilt DS 1 ; Mode2 Filter MTwoOldA DS 1 ; Mode2 Old Value for port A MTwoOldB DS 1 ; Mode2 Old Value for port B MTwoOldC DS 1 ; Mode2 Old Value for port C MTwoFCntA DS 1 ; Mode2 Filter Counter for port A MTwoFCntB DS 1 ; Mode2 Filter Counter for port B MTwoFCntC DS 1 ; Mode2 Filter Counter for port C MTwoReadA DS 1 ; Mode2 Read Filter Value for port A MTwoReadB DS 1 ; Mode2 Read Filter Value for port B MTwoReadC DS 1 ; Mode2 Read Filter Value for port C MTwoFlags DS 1 ; Flags for Mode 2 ; *** MTwoFlags *** TX_PortA = 0 ; Transmit Port A now TX_PortB = 1 ; Transmit Port B now TX_PortC = 2 ; Transmit Port C now ; *** Bank 9 *** ORG $90 SPI_BANK = $ spim_rate_counter DS 1 spim_bit_count DS 1 spim_in_dat DS 1 spim_out_dat DS 1 GPIOA_State DS 1 ARPE_BANK = $ hostsmIP3 DS 1 ; host subnetmask address hostsmIP2 DS 1 ; " hostsmIP1 DS 1 ; " hostsmIP0 DS 1 ; " hostgwIP3 DS 1 ; host gateway IP address hostgwIP2 DS 1 ; " hostgwIP1 DS 1 ; " hostgwIP0 DS 1 ; " ;GPIO_BANK = $ ; *** Bank A *** ORG $A0 FLAG3_BANK =$ flags3 DS 1 ;used for flags ; *** flags3 *** TURN_LED_ON = flags3.0 ; Tell system to turn LED on TURN_LED_OFF = flags3.1 ; Tell system to turn LED off MODE2_SCAN = flags3.2 ; Flag to tell main loop to check mode 2 signals FIFO_EEPROM = flags3.3 ; Indicates there is data in the FIFO for the EEPROM MODE2_ENABLE = flags3.4 ; Tells System that Mode2 is enabled and to scan when timer expires EEBLANK = flags3.5 ; Tells System that EEPROM is Empty FIXTEN = flags3.6 ; Fix the IP at 10.10.10.10 DHCP OFF FIX192 = flags3.7 ; Fix the IP at 192.168.0.X DHCP OFF ; *** Bank B *** ORG $B0 ; *** Bank C *** ORG $C0 ;FIFO BANK 1 OF 4 used for data ring buffer for transmit data from UDP application ; *** Bank D *** ORG $D0 ;FIFO BANK 2 OF 4 used for data ring buffer for transmit data from UDP application ; *** Bank E *** ORG $E0 ;FIFO BANK 3 OF 4 used for data ring buffer for transmit data from UDP application ; *** Bank F *** ORG $F0 ;FIFO BANK 4 OF 4 used for data ring buffer for transmit data from UDP application ; *************** ; *** EQUATES *** ; *************** ; *** Pin Definitions *** RA_DIR = %00000010;%10000000 RA_OUT = %11111111;%00000000 RA_LVL = %11111111;%11111111 RA_PLP = %00000000;%01111111 RB_DIR = %11111111 RB_OUT = %00000000 RB_LVL = %11111111 RB_PLP = %11111111 RC_DIR = %11111111 RC_OUT = %00000000 RC_LVL = %11111111 RC_PLP = %11111111 RD_DIR = %11111111 RD_OUT = %00000000 RD_LVL = %11111111 RD_PLP = %11111111 RE_DIR = %11111111 RE_OUT = %00000000 RE_LVL = %11111111 RE_PLP = %00000000 NIC_DATA_PORT = re ;NIC_CTRL_PORT = ra ;IOWB_PIN = NIC_CTRL_PORT.5 ;IORB_PIN = NIC_CTRL_PORT.6 ;IOCH_PIN = NIC_CTRL_PORT.7 SPI_CLK = ra.0 ;OUTPUT SPI_SDI = ra.1 ;INPUT SPI_SDO = ra.2 ;OUTPUT SPI_CS = ra.3 ;OUTPUT ; *** flags *** RX_IS_ARP = 0 ; incoming packet is an ARP packet RX_IS_ICMP = 1 ; incoming packet is an ICMP packet RX_IS_UDP = 2 ; incoming packet is a UDP packet RX_IS_TCP = 3 ; incoming packet is a TCP packet RX_IS_IP_BCST = 4 ; incoming packet is an IP Broadcast packet GOT_DHCP_OFFER = 5 ; received DHCP IP address offer GOT_IP_ADDR = 6 ; received an IP address assignment (recv'ed DHCP ACK) IP_CHKSUM_LSB = 7 ; next byte to accumulate IP checksum is LSB ; *** flags2 *** ARP_REQ_SENT = 0 ; indicates that an ARP request has been sent ARP_RSP_RCVD = 1 ; indicates that an ARP response has been received ARP_STL_TX = 2 ; indicates that the stalled packet is to be transmitted GOT_RX_FRAME = 3 ; used by NICWaitRxFrame to indicate we got one. GOT_IP_LEASE = 4 ; indicates that an IP lease was granted by a DHCP server RENEW_IP_LEASE = 5 ; indicates an IP lease renewal is in progress FIFO_DATA = 6 ; Indicates there is data in the FIFO to transmit to the host DHCP_ENABLE = 7 ; If this is set then get IP by DHCP else use fixed IP ; available for future use
Cheers
Stolzie
