sx28 resetting...power supply?
I am having a problem with my sx28 chip resetting occasionally.· I am not sure if this is happening while the chip is in operation or during power up/down.· I have about 50 of my circuits in the field with a failure rate of about 1 every two weeks.· The circuits operate about 12hrs a day.
I am using a ATX power supply that seems to power down slowly.· Could this be the problem?·· I have the circuit directly connected to the ATX with no filters.
Zach
Zach
Are you using a 10K resistor on the MCLR pin ?
Are you using a brown-out reset setting on the device line (like "BOR42") ?
Bean.
The first rule to being successful is "Learn from your mistakes",
The second rule is "Be willing to make mistakes"
www.hittconsulting.com
zach
When your chip "resets", do you do a read and verify of the code and the IDE says that the code in the chip isn't matching the code in the IDE?
PeterM
I can think of two sources for this. One is a small motor that runs on the 12 volt line of the power supply. The second is the actual power supply itself.
What do you think?
HTH, Chris
I'm not scared of your robot. I'm covered by Old Glory (youtube)
You didn't answer my question. Did you do a verify on the "reset" chips and find that the program was erased? It now sounds like your problem isn't that the program was erased as you first indicated, but that you have damaged I/O lines. In order to determine that the chip's program was erased, you need to verify this using the tools you already have, otherwise you're just guessing.
PeterM
