ExpressPCB production >.<
Hi-
I'm thinking of using ExpressPCB to make the board for my science fair project this year. I like the software and the Mini board option sounds good, but if I want soldermask and silkscreen, their cheapest option is the $179 for 4 boards. However, I only need a maximum of two boards (even the second one might not be neccessary) and so it seems a waste to use that service. Are there any other fab houses that take ExpressPCB files (yes, I know they're encoded etc.)? If not, what are other options for making one or two small boards w/ siklscreen and soldermask a little cheaper?
Rafael
You've got to play the game.
You can't win.
You can't break even, except on a very cold day.
It doesn't get that cold.
~Laws of Thermodynamics~
Rafael
You can't win.
ExpressPCB will let you put multi PCBs on one panel. Try to find someone that will share the cost by putting one of your PCBs and one of their PCBs on each panel.
What are the dimensions of your PCB ?
Bean.
The first rule to being successful is "Learn from your mistakes",
The second rule is "Be willing to make mistakes"
www.hittconsulting.com
Rafael
You can't win.
Use your ExpressPCB software to look at the example I enclosed below.
deno
Deno
Although they don't support the ExpressPCB format, so you'd have to use another program to create your board.
Either way will save you $$$, even with the practice boards.
