Demo board schematic for prop plug has an error
I used a USB to Serial converter to make the prop-plug shown in the demo board schematic but couldn't get it to actually identify a prop. I blamed by circuit and tried breadboarding another prop and experimenting. In the end it turned out to be the RX and TX lines being the reverse of what is needed.
The schematic shows TX on the USB chip going to P31 and the RX going to P30 while in reality those need to be reversed. Quite the relief for me really, since I went ahead and etched a little prop board without breadboarding first. Thought for a while there I had to make another!
Paul Baker
When you "transmit" something out of the PC it becomes somthing "received" at the USB-Plug/Prop Interface!
Example.
DTE ----- DCE ......... DCE ------ DTE
DTE ----- [noparse][[/noparse] null modem = two headed DCE ] ------ DTE
Prop ----- USB-Plug ......... Cable-Plug ------ PC
Post Edited (deSilva) : 8/31/2007 5:53:12 AM GMT
