making a connection
My mission is to use the bs2 (preferably 1 I/O pin) to short out 2 pins on another circuit. I dont want to get into what the pins are for. All I need is to make these two pins connect with each, using the bs2 to be say when they connect and whey they arn't. They only need to stay connected for a small moment, such as a button push, ok thats how I can describe it. Instead of connecting these two pins to a push button I am connecting them to a bs2 to do the connecting. how can I make the bs2 connect the two pins together?
Actually I think Im going to add the whiskers to my tank and let it roam, just need to figure out where.
····http://forums.parallax.com/showthread.php?p=667254
I take it you've given up on the relay. It would be helpful, though, it you could tell us the following about the pins you want to short:
····1. AC or DC?
····2. When open, how many volts between them?
····3. When closed, how much current?
If the common ground thing is a problem, you will need to use an optoisolator. Emitter and collector are connected the same as with a transistor. The Stamp pin will need to drive the opto's LED through a 220 ohm resistor.
Good luck!
There's nothing like a new idea and a warm soldering iron.
For example, if you have the base to IO pin 6: HIGH 6 will connect (short)·the pins and LOW 6 will disconnect them.
