Making my own PCB questions...
I understand how to get the board etched (I use the positive photo resist method), however, I do not know how to do silkscreens. I'd also like to know how to do solder stencils, through-hole plating and such. I know that there are board houses that will do all of this for me, but I get great joy from doing it myself whenever possible.
Any help?
Mark
Any help?
Mark
I did have the Idea to create a pseudo soldier mask. make the board like normal but before taking off all of the photo resist, make a positive that would expose only the pads that were to get soldiered. expose the board and use the solvent to get rid of the photo resist over the newly exposed areas leaving it over the traces.
I've also thought about printing what I want silk screened onto clear "sticky back" paper and putting that on the board, but I haven't tried it.. I'm not so sure it will drill well and the heat from soldering could be an issue also.
I usually put any text or lines (that won't cross traces) in the copper rather than have silk it screened.
I just think it's there is just too much equipment and harsh chemicals involved in the process for anyone to market it for a hobbiest
If you find anything I'd love to know
good luck
A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
Take a look at this for making through holes.
http://www.solder.net/marketplace/product_desc.asp?Sku=BEST%20Through-hole%20Repair%20Kit&Category=108
When I said solder stencil, I meant solder paste stencil to apply the solder paste more accurately. I'm not real concerned with solder masking. Ther has got to be a way to do silk screening.
LPKF has a decent silver based through hole product. It doesn't take heat very well from a pencil. There is not a great solution to home made through holes that I have seen, LPKF being the best but still a hassle, and costly too, maybe $20 per board.
Solder masking is not really needed on home made boards.
I think I'll just cut a short piece of single strand wire, insert it into the holes and solder. There are only going to be 4 vias on the board I'm designing anyway. I may just end up rerouting the board to a one-sided board and use jumpers.
Go to ULP and find DXF export when on the pads layer
Short wire is the way I used to go, LPKF is very iffy. Chasing busted vias is not fun.
Post Edited (TChapman) : 8/30/2007 5:49:16 AM GMT
HUH?!? ULP? I'm still trying to figure this program out. It was clearly not made to conform to any U.S. software standards.
http://www.sparkfun.com/commerce/present.php?p=Stenciling
http://www.pulsarprofx.com/PCB/a_Pages/4_Products/4b_TRF_Foils/TRF_Foils.html
