can use BS2 to drive flash memory ??? — Parallax Forums
YHYYHY Posts: 3
edited 2007-08-29 20:48 in BASIC Stamp
I want to use BS2 and eb500 to send data.
The data in the flash memory.
The flash memory is an external device.
My question:
Can use·BS2 to·drive the flash memory then access data through·the computer ?!?!
I don't know this idea may or may not realize.
Hope someone can·help me.
give me some suggestions.
Thanks a lot.
  • allanlane5allanlane5 Posts: 3,815
    edited 2007-08-29 13:32
    No, the USB protocol requires a 'master' and a 'slave' device. The complexity of the 'master' device requires a PC with a hard disk -- though people are working on this part of the solution.
    In any event, currently a BS2 cannot be a USB 'master' device, so you can't directly read or write a USB Flash Memory module this way.
    However, you CAN use the computer to access the USB Flash memory, then send to the BS2 from the computer.
    edited 2007-08-29 13:55
    Actually, the Parallax Data Logger might be able to do this for you. It's a device that can act as a USB host and can access data on a USB flash drive. It's usable with a Stamp ... There are example programs on the Parallax webstore page for it. Have a look.
  • BeanBean Posts: 8,129
    edited 2007-08-29 14:01
    I'm with Mike. Here is the link http://www.parallax.com/detail.asp?product_id=27937
    Bean.
    The first rule to being successful is "Learn from your mistakes",
    The second rule is "Be willing to make mistakes"
    www.hittconsulting.com
  • NewzedNewzed Posts: 2,503
    edited 2007-08-29 16:35
    Mike, will the Data Logger work with my Cruzer mini 128Mb SanDisk?
    Sid
    Yesterday is history, tomorrow is a mystery, and today is a gift.
    That is why they call it the present.
    Don't have VGA?
    Newzed@aol.com
  • pwillardpwillard Posts: 321
    edited 2007-08-29 17:11
    Has anyone had success with the FTDI Viniculum chipset products? IE: VDRIVE?
    http://www.vinculum.com/prd_vdrive1.html
    There's nothing like a new idea and a warm soldering iron.
  • UnsoundcodeUnsoundcode Posts: 1,532
    edited 2007-08-29 17:18
    pwillard, I have the Vdrive 2 and Stamp communicating quite happily, although I don't have the Parallax logger as of now I believe they operate with the same commands.
    They provide a large amount of storage (to 4G) and allow for many applications where the EEPROM is just not large enough. Such as·databases for RFID or barcodes for example.
    Jeff T.
    edited 2007-08-29 17:25
    Newzed,
    The data logger (and any Vinculum chip based device) should work with any USB flash memory drive, for that matter you can plug in a USB hard disk and it should work ... any device that works like a "mass storage device" as far as USB is concerned. The only concern is size ... The Vinculum only works with FAT16 so devices larger than 4GB (I think) are not usable currently.
    Wow! Well, there you go, I did not know that had been released. Way to go Parallax!
