uALFat Baud Rate
Hi all,
In my latest project I needed FAT32 support so I got a uALFat chip, and I am trying to interface it to the propeller.
I am using the serial interface with the FullDuplexSerial object. And I can talk to the the chip but I want to use a baud rate over 9600. But when I try to change the baud rate of the chip, then change the serial objects baud rate, I can't communicate with the chip any more
Has anyone tried to change of this chip, and if so what did you have to do to make it work?
Or should I just bag the Serial and go for SPI?
-Kit
.Has anyone tried to change of this chip, and if so what did you have to do to make it work?
-Kit
For the I2C you can get up to the 400KHz spec without trouble, and since you already have to dedicate pins for SDA and SCL, the only penalty is the handshaking line.· I only use one handshaking line to see if the uALFAT still has data.· The only precaution I can give is that you'll need a START, COMMAND, DATA, STOP for each character, so it's twice as chatty as it needs to be.· Even still,·you can move 4K images in 400mS.
Oh yea, the uALFAT also has a 512 byte buffer, so you'll get 512 bytes then the uALFAT will go silent for·5 mS while it fetches more data.· I was streaming audio and needed a buffer to get over the dead period.
I tried to do this, but I couldn't figure out how to make the I2C object work in the rite way.
Could you post some code snippets for how you implemented it.
Thank you
-Kit
{*******************************************ReadAlfat********************************************* It's a pain, but the Alfat can only read one byte at a time, so all transfers are twice larger than the really need to be because you have to address the chip all over again **************************************************************************************************} ReadAlfat '--- Setup Normal Condition --- andn dira, HandShake 'Make sure it's an input :Loop 'Wait until ready mov dataByte, ina 'Grab the handshaking line test dataByte, HandShake wz 'Is it low? if_z jmp #:Loop ' Yes, cycle until ready call #StartCondition 'generate start condition mov dataByte, #$A5 'The Alfat's read address call #SendByte 'send device address byte call #CheckAck 'check for ACK from eeprom '--- Read Byte --- call #ReceiveByte 'receive byte wrbyte dataByte,BufferAddress 'store received byte into buffer add BufferAddress,#1 'increment buffer address sub paramByteCount,#1 wz 'decrement number of bytes left wrlong paramByteCount,byteCountAddr 'let other cogs know the progress so far test LongMax,#1 wc 'set C to 1 for "No ACK" (meaning "done") call #SendBit 'send "ACK"/"No ACK" call #StopCondition 'generate stop condition if_nz jmp #:Loop 'loop ReadAlfat_ret ret {*****************************************StartCondition***************************************** I2C is supposed to idle SCL and SDA high, and I believe this has caused a number of timing problems, so everything will be changed to make it more robust and faster *************************************************************************************************} StartCondition or outa,datMask 'Make sure data and clock are high or outa,clkMask 'pull clock high or dira,datMask 'set data pin to output or dira,clkMask 'Verify clock is too mov timer, #T_HIGH 'Get the high period add timer, cnt 'Add the time waitcnt timer, #T_HIGH 'Wait and get ready for next high period andn outa,datMask 'pull data low waitcnt timer, #T_HIGH 'Wait and get ready for next high period andn outa,clkMask 'pull clock low waitcnt timer, #T_HIGH 'Wait and get ready for next high period StartCondition_ret retThere is no error checking if the uALFAT doesn't respond because in my application it wouldn't matter, the machine would be broken, so you may want to add some sort of abort to the handshaking loop.· The main issue with the Hydra driver is the way waitcnt is used for bit timing.· It·gets a little flakey when you·reach full speed·and that's why I·wanted to rewrite it.· You'll want to make sure that each transfer starts with reloading your timer, or else waitcnt will roll over and you'll be stuck waiting·50 seconds for the next bit to shift out.
