can use BS2 to drive flash memory ???
I want to use BS2 and eb500 to send data.
The data in the flash memory.
The flash memory is an external device.
My question:
Can use·BS2 to·drive the flash memory then access data through·the computer ?!?!
I don't know this idea may or may not realize.
Hope someone can·help me.
give me some suggestions.
Thanks a lot.
My question:
Thanks a lot.
In any event, currently a BS2 cannot be a USB 'master' device, so you can't directly read or write a USB Flash Memory module this way.
However, you CAN use the computer to access the USB Flash memory, then send to the BS2 from the computer.
Bean.
The first rule to being successful is "Learn from your mistakes",
The second rule is "Be willing to make mistakes"
www.hittconsulting.com
Sid
Yesterday is history, tomorrow is a mystery, and today is a gift.
That is why they call it the present.
Don't have VGA?
Newzed@aol.com
http://www.vinculum.com/prd_vdrive1.html
There's nothing like a new idea and a warm soldering iron.
They provide a large amount of storage (to 4G) and allow for many applications where the EEPROM is just not large enough. Such as·databases for RFID or barcodes for example.
Jeff T.
The data logger (and any Vinculum chip based device) should work with any USB flash memory drive, for that matter you can plug in a USB hard disk and it should work ... any device that works like a "mass storage device" as far as USB is concerned. The only concern is size ... The Vinculum only works with FAT16 so devices larger than 4GB (I think) are not usable currently.
