Speedtrap project...need some help
For those of you who responded to my CMUCam post, thanks.· I'm not going to pursue it due to the complexity and cost involved though, considering there's still quite a bit of uncertainty involved.
Anyway, my next project is for the velodrome as well.
What I need to do is time riders on a 200M course on the velodrone.· I'd like to use electric eyes connected to the stamp.· When the rider breaks the "start" beam, the timer is started, and when he breaks the "finish" beam, the timer is stopped.· The time is then displayed.· So far I think I can handle this.· For the hardware gurus, I was wondering if it's feasible to locate the stamp at the finish line, and connect the "start" beam with about 100 feet of wire.· Would having 100' of wire skew the timing results at all?· Even though the stamp is going to be located at the finish line, should·I also connect the "finish" beam with an equal length of wire to approximately duplicate any wire resistance that exists in the "start" beam?· I know·this could be done wirelessly, but·I need to keep costs down.
The second phase of the project would add 2 more electric eyes to create 2 "speedtraps".· The first one would be placed exactly 1 meter beyond the "start" beam, and the second one would be placed exactly 1 meter before the "finish" beam.· By using 2 sets of beams,·I should be able to measure the rider's starting and finishing speed, as well as·his elapsed time.
I think I've worked out the math that will give reasonable results on a Basic Stamp.· I hope you math gurus can point out any mistakes I've made:
T = time in ms for rider to travel 1 meter
VM = 1000000 / T· (This should give meters per second, "shifted" for use without floating point math)
MPH = (3600000 * VM) / 1609344 (3600000 is the number of seconds in an hour, "shifted".· 1609344 is the number of meters in a mile, again the number is "shifted".)
For example, the rider crosses the speedtrap in 60ms.
With normal math, I can calculate like this:
T = 60ms
VM = 16.666 (1000ms / 60ms)
MPH = (3600 * 16.666) / 1609.344 = 37.28
MPH = 37.28
With the Basic Stamp's math,·I calculate like this:
T = 60ms
VM = 16666
MPH = (3600000 * 1666) / 1609344 = 3726
MPH = 37.26 (I will add the decimal place manually)
I've tried several examples, and it seems to work, but I'm worse with math than I am with hardware, so I may have made some mistakes.
T = 60ms
MPH = 37.28
T = 60ms
VM = 16666
If your sensor looked down at the riders instead of sideways and your light curtain worked in cells (bike width, triggered by the light trigged first then being the center of the cell) You could get away with catching who crossed first, second and so on no matter how close the race is.
At this point you just need to know which rider is which as they cross the line.
setting the speed traps at start if they start staggered shouldn't be too big of a hassle using side triggers. End speed traps would need to work like the finish line and you would need to know where the rider is at the finish line (if they changed lanes).
otherwise they need some type of xmitter (ir, am,fm,whatever) to be used as an identifier. (There's always RFID, kind of a tight industry though, you may have to hire an RFID expert).
Post Edited (cyplesma) : 8/29/2007 12:45:03 AM GMT
MPH=2237/T 'whole number
MPHDec=2237//T*100/T 'decimal portion (mantissa)
DEBUG DEC MPH,".",DEC2 MPHDec,CR 'output
Have Fun
TR
Post Edited (TechnoRobbo) : 8/30/2007 1:39:12 AM GMT
Can anyone comment on the wire length for the electric eyes?
One solution to this would be to use an RS423 driver, along with a shielded twisted-pair cable, to an RS423 reciever at the BS2. The RS-423 driver has the current drive, and impedance matching, to send a nice sharp square wave 4,000 feet. So 100 feet should work great. You'll need to send power down the cable to the 'satellite module' which holds the RS423 driver and the 'beam-breaker' module. Probably Cat-5 cable would work well for both power and signal for this.
Have Fun
TR
PeterM
In any digital capture of events like this, the resolution of time is at best the length of one data sample;·the start sample occurs some time after the rider passes and you count sample intervals until the rider passes the finish: you get an even number of sample intervals. You don't know when within that sample time the event actually occurred... could have been the beginning of one and the end of the other.
You don't have to worry about response time of the sensor if it's the same for starting and ending a lap: equal length wires, the same sensors, etc. You can use various means to make sure the analog signal lasts long enough to be detected, and you need to know how long the A/D is actually reacting to the input signal. You may sample at 1 kHz but be using an A/D that gets its value in 10 microseconds... it will miss any event during the 1000 microsecond sample window that doesn't occur while it's on. Your event has to be seen for the full sample period to be sure that the A/D picks it up.
AP
Post Edited (FerretMK4) : 8/30/2007 9:51:19 PM GMT
Anyway, it is an outdoor track.· While most of the racing is at night, the system will need to be flexible enough to use in a day or night situation.· I think to start with I will ditch the electric eye system in favor of the force sensing tape method shown above.· It seems more reliable and easier to implement.
Once I work out the other kinks in the system (and I'm sure there will be some), I'll think about upgrading to a laser type trap.
Thanks again for all the suggestions everyone.· I'm sure I'll need your help in the future!
If you use the tape it is the same method used by ALL the world class velodromes. you can leave the tape on the track all-year and setting up will be just hooking up the wires in the infield, or if your lucky not to have people jumping the fence to goof on the track you could leave the wires.
The laser would be subject to an extensive set-up tear-down, and spectators feet kicking the laser and guys riding (or crashing) into the sensor. The sensor would have to be right at the black line do to the apron being level and the 200 line at 30-40 deg. you would have to re-align that thing all the time and it would be dangerous for the rider if he hit it and flatted.
Where is your home velodrome?
I'm at Brian Piccolo Velodrome in FL. It's an outdoor 333 with 28 degree banks.
Do you (or anyone) have a source for this tape? As far as I can tell, what·I need is called "Ribbon Switch", but I can only find one company (TapeSwitch) that makes it. It's also rediculously expensive. A 50 foot roll costs about $473 - $618. At that price, I will not be able to do this project. I must be looking at the wrong stuff. I need about 120 feet to make 4 sensors (start and finish lines, incorporating 2 speedtraps). The switch doesn't need to activate with just a few oz of weight. The weight can certainly be about 7-10 lbs if that makes it cheaper.
If you only want 200 times and a speed trap why not tape 3 feet at the bottom? that is how all the 200 lines are done. most finish lines are full length but you don't need it if you are only doing TT's and not the last 200 of a match sprint where guys are all over the track.
