pwm command
····· I am using the bs2 to create a pulse width, It works good I can see it increase in voltage when it is told to, on my scope but what I am trying to do is control a 1 amp proportional valve now is it possible to control it with the bs2?
Thank-You
Toby
Thank-You
Toby
Toby
What cap resistor circuit are you talking about?
Voltage Divider?
Toby
just a quick reminder always create you circuit with switches in place of the stamps output and leds in place of the stamp's inputs.
If you have the transistor on hand and you create the circuit to replace the stamp's I/O with switchs /leds then use your test equipment to make sure it does what you want it too.
If you haven't order/bought the transistor yet then maybe do a check on other electronic sites for that trans or one that will do what you want it do.
I don't mean to sound dumb, but I know I often forget easy ways to check things.
