Newbie needs help with a RF project
Hi,
I'm new to the embedded programming and electronics. I want to duplicate a project shown here: http://www.rentron.com/Stamp_RF.htm· My problem is that I do not know what I'll need to create the project. I know that I'll need the tx and rx and a BS1 stamp and I believe I'll need·a couple of carrier boards or breadboards.·I downloaded the Windows based IDE for the STAMP. Could·someone please take a quick look at the project and·let me know what I'll need to purchase to complete the project.
I want to welcome you to the Parallax Forum..............................
What i would do frist would is down load WAM and do the Little Projects frist
then move on to this Project
·(This is what· WAM is·)··· "What's a Microcontroller?"··v2.2 (315 pp.)
Here is the link·http://www.parallax.com/dl/docs/books/edu/Wamv2_2.pdf·
Here is an link to a Basic Stamp 1 Board
http://www.parallax.com/detail.asp?product_id=27100
Get a good understanding of the Basics Frist it helps
Here is some of what you will need and·I only look at it for a·few minutes so i do not know what else you will need
http://www.rentron.com/remote_control/TWS-4-bit-combo.htm
And it alot of fun· I hope that you will also have alot of fun with as well
Here is just a few Project that i have·done with a Basic Stamp
These are all Parallax parts
Card Reader Gate opener· with a
Basic Stamp 2
RFID Card Reader
Pool Pump Timer
Basic Stamp 2
DS1302 Time Chip
Soldering Station Timer
Basic Stamp 2
RFID Card Reader
DS1302 Time Chip
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 8/27/2007 9:05:17 PM GMT
Also, you could just buy a protoboard and solder the components on (if the project is permanent)
OR you could buy a proto board and sockets. (For a semi-temporary project)
I agree with sam_sam_sam that you should probably read that documentation. But, I think you don't have to do the experiments if you understand it. Do the RF parts themselves have datasheets to read to see how they work?
Post Edited (D Faust) : 8/28/2007 11:01:14 AM GMT
- Stephen
If you want to do this with a breadboard, get a Stamp Activities Kit which includes a BS2 on the board and a small breadboard area. Another option would be to get a Board of Education (BoE) and one of the Stamps. I'd get a BS2p or BS2pe or BS2px because of their additional features that might be useful for other projects.
If you do want to use the BS1 for the first project and want a breadboard area, get the BS1 Homework Board (I think that's the right name).
You'll need a USB to serial adapter if your PC has only USB and no built-in serial ports. Get Parallax's or FTDI's or Keyspan's High Speed adapter. You'll also need a power source. If you use an AC supply, get a 7.5VDC adapter like the one's sold by Parallax. You can run these boards off 9V, but 7.5V is better since it generates less heat in the voltage regulator.
I was under the impression that the BS1 stamp was used with the tx and the BS2 was used with the rx -- all in one project. Is this not correct?
